PMDG 777 Aircraft Power using the MCP-PRO
Hello, I have read and tried everything to get the mcp pro to be in a cold and dark state while my pmdg 777 is powered down and for the mcp pro to turn on when I power up the aircraft but I cant seem to figure out how to get it to work. I read that you have to use the battery variable but even that did not work for me. Any suggestions?
  • Have you tried using DATA_OH_ADIRU_LIGHT_BATTERY_ON with ON and 1?
  • edited May 2018
    tried the switch one instead of age adiru light and it worked! thanks so much steve
  • Ok, DATA_OH_ELEC_SWITCH_BAT with ON and 1 does work. You may need to quit GIT and restart it.
