PMDG NGX Locks GIT
Some advice pls.
I'm running Prepar3d Version 4.2.21.24048 with SimConnect Version 4.2.0.0 and also GIT P3Dv4 64Bit.
Everything is fine with GIT, all green light, or a yellow SimConnect light, using any of the stock P3Dv4 aircraft, but as soon as I load the PMDG 737NGX GIT locks up.
I have [SDK] EnableDataBroadcast=1, entered into the 737NGX_Options.ini file.
I've tried replacing the UIAutomationCore.dll file in the P3Dv4 folder with the file in Windows32 folder.
I've deleted and reinstalled the PMDG 737NGX, all to no avail,
I'm running Windows10 on a Intel I7-8700 CPU @ 3.2 GHz, 16Gb RAM on a 64-bit Operating System.
Any advice would be much appreciated.
Cheers
Graham McAllister
Cheers
Graham McAllister
I notice there are quite a few OUT_OF_BOUNDS exceptions, which, according to the FAQ's indicates the DLL is not installed, however I'm running GIT is the GoFlight folder?
16:31:29 GoFlight Connection Starting.....
16:31:29 SimConnect Connection Starting.....
16:31:29 SimConnect Message Processing Started
16:31:29 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:31:29 SimConnect: Event Received: SIM, 1
16:31:29 SimConnect: Event Received: PAUSE, 0
16:31:29 GoFlight Connection Started
16:31:29 SimConnect Connection Started
16:31:29 Aircraft Connection Starting.....
16:31:30 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:32 WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
16:31:32 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
16:31:34 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
16:31:34 Aircraft Connection Started
16:31:34 Simconnect Version: 4.0.0.0
16:31:34 Aircraft FullName: IRIS Raptor Driver
16:31:34 Synchronising Switches & Selectors .....
16:31:34 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:35 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:36 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:37 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:38 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:39 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:40 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:41 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:42 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:43 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:44 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:45 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:46 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:47 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:48 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:49 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:50 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:51 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:52 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:53 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:54 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:55 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:56 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:57 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:58 SimConnect: Exception Received: OUT_OF_BOUNDS
16:31:59 SimConnect: Exception Received: OUT_OF_BOUNDS
16:32:03 Synchronising Switches & Selectors Complete
16:36:42 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:42 SimConnect: Exception Received: ERROR
16:36:42 GoFlight Connection Starting.....
16:36:42 SimConnect Message Processing Finished
16:36:43 SimConnect Connection Starting.....
16:36:43 GoFlight Connection Started
16:36:44 SimConnect Message Processing Started
16:36:44 SimConnect Connection Started
16:36:44 Aircraft Connection Starting.....
16:36:44 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:36:44 SimConnect: Event Received: SIM, 1
16:36:44 SimConnect: Event Received: PAUSE, 0
16:36:45 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:47 WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
16:36:47 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
16:36:49 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
16:36:49 Aircraft Connection Started
16:36:49 Simconnect Version: 4.0.0.0
16:36:49 Aircraft FullName: IRIS Raptor Driver
16:36:49 Synchronising Switches & Selectors .....
16:36:49 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:50 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:51 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:52 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:53 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:54 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:55 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:56 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:57 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:58 SimConnect: Exception Received: OUT_OF_BOUNDS
16:36:59 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:00 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:01 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:02 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:03 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:04 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:05 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:06 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:07 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:08 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:09 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:10 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:11 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:12 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:13 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:14 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:17 Synchronising Switches & Selectors Complete
Cheers
Graham
See the entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" in the FAQ here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
If that doesn't work, try using the non 64bit version of GIT for P3D.
Are other aircraft working OK with GIT?
I'm using the PMDG 737-6900 Base package only, file version 1.20.8465 which I believe the latest version of the NGX. I'm also starting P3Dv4 with a default aircraft before loading the NGX.
As previously stated I have the [SDK] EnableDataBroadcast=1in the 737NGX_Options.ini file as well as having Enable for PMDG/Prepar3D checked in the GIT settings. I'm also loading both programs P3D and GIT as Administrator and I have the latest .NET ver 4.7.2 installed.
I've tried the non 64 bit version of GIT but to no avail.
I've loaded every stock aircraft with P3Dv4 and they all work fine with GIT, two green lights and a yellow Simconnect.
Cheers
Graham
Have you tried uninstalling and reinstalling GIT? In fact uninstall all GIT versions and the GoFlight Drivers and install the lot into C:\GoFlight instead of C:\Program Files (x86)\GoFlight.
Well uninstalling p3D and the GoFlight software didn't work, but being a new pc, with a brand new HD I uninstalled everything again and installed it all on the D drive and for the time being it is working with the NGX.
I've got a mountain of scenery, utilities, etc to install so time will tell, but thank you so much for your time and effort.
Cheers
Graham
