thks
When you say you have the same problem with the iFly and 737 do you mean Goflight's own drivers don't work with FSX?
How do i know i need simconnect sdk driver because i dont have this file i used microsoft
Flight simulator aceleration fsx
Hi John,
Simconnect is installed automatically by FSX.
I think lets get back to basics and test with a default aircraft. Start GFConfig and configure the MCP PRO for FS Default. Quit GFConfig.
Load FSX. Do not start PMDG Interface or GIT. Make sure you have a blue and black aircraft icon in your Windows notification bar. Load up a default aircraft and make sure the MCP PRO works with it.
like i told you i re install all again .
course 000 same pdmg
ias-mach mcp light off fsx 110
heading 258 cmp fsx 100
altitud mcp 257 fsx 10000
vert speed mcp 512 fsx light off
LOG COPY
17:04:38 GoFlight Connection Starting.....
17:04:38 SimConnect Connection Starting.....
17:04:41 GoFlight Connection Started
17:05:44 SimConnect Message Processing Started
17:05:45 SimConnect Connection Started
17:05:45 Aircraft Connection Starting.....
17:06:03 SimConnect: Event Received: Start
17:06:04 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:06:04 SimConnect: Event Received: SIM, 0
17:06:04 SimConnect: Event Received: PAUSE, 0
17:08:08 SimConnect: Event Received: SIMSTART, 0
17:08:08 SimConnect: Event Received: SIM, 1
17:08:34 SimConnect: Event Received: SIMSTOP, 0
17:08:34 SimConnect: Event Received: SIM, 0
17:08:49 PMDG SDK option is OK in FSX
17:08:49 SimConnect: Event Received: Aircraft Type Changed
17:08:49 GoFlight Connection Starting.....
17:08:50 SimConnect Message Processing Finished
17:08:50 SimConnect Connection Starting.....
17:08:51 GoFlight Connection Started
17:08:51 SimConnect Message Processing Started
17:08:51 SimConnect Connection Started
17:08:51 Aircraft Connection Starting.....
17:08:53 Aircraft Connection Started
17:08:53 Simconnect Version: 10.0.61259.0
17:08:53 Synchronising Switches & Selectors .....
17:08:53 Synchronising Switches & Selectors: Waiting for Simconnect .....
17:08:56 SimConnect: Event Received: Start
17:08:56 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:08:56 SimConnect: Event Received: SIM, 0
17:08:56 SimConnect: Event Received: PAUSE, 0
17:08:56 SimConnect: Exception Received: EVENT_ID_DUPLICATE
17:08:58 SimConnect: Event Received: SIMSTART, 0
17:08:58 SimConnect: Event Received: SIM, 1
17:09:02 SimConnect: Exception Received: ERROR
17:09:03 SimConnect: Exception Received: UNRECOGNIZED_ID
17:09:03 SimConnect: Exception Received: ERROR
17:09:04 SimConnect: Exception Received: ERROR
17:09:06 Synchronising Switches & Selectors Complete
