Rex advantage radar and GFIT in detective mode FSX
hi everyone
i just bought rex advantage radar to use with GF hardware and GFIT after watching the excellent video tutorial from Rob Ainscough.
but in detective mode under FSX and windows 7 only the event number is showing and not the event name. everything is working fine and showing in detective mode for the piper cheyenne from digital aviation. thanks for your help. Daniel.
If the standard events and aircraft events are appearing OK, I guess Rex haven't named their events.
Yesterday gfit and rex advantage radar worked perfectly, the event name for rex advanrage radar was showing in the event name, I saved my configuration by exporting evetything for my goflight rp48 hardware.
But today everything disapeared for rp48 I m using for rex wx radar when I started gfit, I tried several time to import my saved file, but I have a erir message , failed to import.
Sometime the event name for rex w radar is detected , but most of the time it s not.
I programmed tilt, gain, range as rotary button, it s working well, but even if I save, import, the configuration, when I turn off and back on gfit, my config disappeared, and I cannot import the saved one, I have an error message, failed to import config.
For the off, test,wx,wxt,map I programmed goflight touch button from goflight rp48 hardware, it was wirking yesterday, but today not at all, wx_radar_modeselect event not showing anymore in gfit.
I did all the install of rex wx radar bybtge book, all permission inbound, outbound in firewall and exclusion in avg antivirus for rex wx radar software.
What can be the problem?
Thanks dear Steve.
I suspect that Rex radar is not initialising everything when the Virtual Cockpit appears. When the VC shows GIT takes a snapshot of everything and that is what is used.
I would advise running some tests to determine at what point GIT sees the Rex radar stuff. e.g. Delay loading GIT until the radar is turned on and see if everything shows. Once you locate the necessary requirements, you will then know when to start GIT for the aircraft concerned.
I will look to see if GIT can be tweaked in some way to support this add-on better, but I will need to know the outcome of your tests first.
