Assistance in Setting up non NGX Aircraft
Hi There
Been Using Steves great utility for sometime now and am immensly greatful for all his efforts
I have now installed the tool but as soon as I try to load up another Aircraft I get nothing, to be honest after reading the manual I dont think I am doing things correctly
Steve has mentioned that it has been tested with the Aerosoft Airbus which is great to hear I am also looking to use it for the PMDG 747
Any Help or guidence would be much apreachiated
Many Thanks in Advance
Paul
Hi Paul,
The product does need configuring for each aircraft so assuming you have done this can you define nothing i.e. provide some screen shots of the status screen and error log.
Hi Paul,
It appears that release 2.0.300.0 had the detective button disabled. A new version has just been released, so try it now.
Hi Paul,
You need to create the following two bespoke events:
Bespoke Event Name: AT On
If MCP_AT_ARM_Switch_var = 0 Next Else Next Skip
Send 72101 with 0()
Bespoke Event Name: AT Off
If MCP_AT_ARM_Switch_var = 10 Next Else Next Skip
Send 72101 with 0()
