Shift mode for RP48
Is there a shift mode feature in GIT for a module like an RP48 ?
ie - where you can have one config for take off and another config for landing to double up the functionality of a module like an RP48 ?
thanks
thanks
No there is nothing built into GIT directly to do this. You could write something in GIT Lua to do this though. E.g. one of your buttons could cycle through setting a global Lua variable which indicates the state of flight e.g. state = 2;
Then for each button write some Lua code that looks at the state variable to determine what event should be sent etc.
