GF-166 not working with ZiboMod 3.29
Ever since ZiboMod 3.29 my GF-166's are no longer working as before.
I had one set up to control Nav1/Nav2 and the second one for COM1/COM2.
It seems that the datarefs are missing multiple commands.
Does anyone have any suggestions?
  • I've got the same configuration and flying 3.29c with no problems. As with the other post I'll save a fresh copy of my profile.
  • Answer ✓
    I'm not having any issues with 3_29c either. I have three 166's and all working fine. I did have a problem last week where I all of a sudden lost 2 out of 3 of them. I never looked at the datarefs so I don't know about that. The problem for me was a windows 10 update. I had to reinstall the goflight drivers and I also went to my Goflight Interface Tool backup folder in the documents folder. Everything came back.
  • Hmm, interesting. I even tried the downloads from the download page here, re-installed the latest driver. Maybe I should just completely remove all interface files and folders and start a clean install of the Interface and config.
    Thank you both for your response.
  • Just to update this thread I am posting here as well:
    Well issue resolved.
    After I installed a clean copy of X-Plane 11 (kept the original installment but changing it's folder name) I noticed that the plugins folder had Commands.txt and Datarefs.txt files that were missing in the original installment. I copied the two files over from the clean install. Performed a clean install of the interface tool, installed a clean copy of the ZiboMod 3.29e. Loaded up the aircraft, and imported the config files David made available.
    And EUREKA!! all modules are now working properly. I am a very happy camper.
    Time to request taxi clearance.
    Thanks for the help David and Dave.
