Hello everyone. my question is because if my GTI works well (three green lights) and all the control
I have a 64-bit m7 window, a ssd that acts as disk c, while flight simulator x steam edition is installed on disk f.
CF Config I installed it in ssd c programs x86 and also Goflight interface too SE.
my mcp pro works perfectly and the displays do not like all the green leds I followed all the guides with and without lua or fsuipc is always the same.
my 737 pmdg is the cd version you can give me a hand I'm building a homecockpit and I'm still at mcp help me thanks
    Do the LED's come on when you click the MCP in GFConfig? If they don't, check that you only have USB2 or USB1 ports connected to the MCP. Note that ALL connections in between the MCP and the PC must be USB 2 or USB1. If the problem remains, use Windows Explorer to go into the GoFlight drivers directory, right click on Windows8Fixer.cmd and select Run As Administrator.
    If this does not fix the problem, unplug the MCP from your PC and run Windows8Fixer.cmd again. Then reconnect the GoFlight hardware. Repeat this process until it all works.
  • edited August 2018
    Windows8Fixer I do not find it could identify the path I tried in c and f but nothing and however I use w7 64 bit
  • Do the LED's come on when you click the MCP in GFConfig?
  • congratulations magnificent support
  • Have you updated the NGX to the very latest version?
  • no, unfortunately, I have the version on dvd
  • The PMDG SDK changed several times as they enhanced the NGX and GIT will only work with the latest version of the SDK. You need to get the update. I think Aerosoft supply it, but I could be wrong. PMDG will advise you on where/how to upgrade. Once upgraded, everything should work OK.
  • 23/5000
    thanks you are fantastic
  • I did as you said I downloaded aereosoft update.
    now everything works fine.
    thank you very much
