My GF-EFIS & MCP stop working
My EFIS and MCP suddenly stopped working. What should I do to restore its function?
I have uninstalled and reinstalled the interface tool but everything remains the same.
rgds
Also look at the FAQ entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
I have already read all the recommendations in FAQ (LED's And Displays Are Not Working) and I have put them into practice but without any positive results for the MCP-PRO.
What else can I do.
Thank you
Done, but nothing changed, still the same situation.
GF, sent me the MCP-PRO - Panel Check and I can see all the switches and buttons are working.
When I start the FS, I can see the LED numbers and the green lights on for 3 seconds and then turn off
rgds
Sorry for the late reply but I stopped working with my FS construction, now I'm back and still have problems with the MCP-Pro.
I did what you told me in your last message and it works with any other airplane of Prepar3D v4, but not with the PMDG 737-800.
Please your assitance.
Rgds
Daniel Gamboa
Double check the steps in the FAQ, its always one of these issues that cause this problem. See FAQ entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
Done. I Followed up the 8 steps in the section indicated by you, but nothing seems to change the situation.
My question is: why the MCP works with the default airplanes but not with the PMDG. I have reinstaled the PMDG several times but still the same. I have the updated version of the PMDG and all the programs/driverrs recomended, but the MCP of GF do not want to recognised the PMDG airplanes.
Rgds
Daniel Gamboa
I think if I have the latest GIT P3Dv4 64bit version. The problem is that I have been blocked to access the PollyPot page and there has been no way to let me in, neither by My Account nor by filling out the form in General Enquires, they say that I am a hacker (?), So I do not know If I have the last GIT version.
In regarding to the PMDG, yes I have the latest version.
Rgds
Daniel Gamboa
You can get the GIT version from Settings, About. Let me know.
Try the standard version of GIT for P3D and see if that resolves the problem.
I finally got in, I have access to the PollyPot page again, now I'm in My Profile but I can not see any GIT version from Settings nor standard version of GIT for P3D.
Where I can find them?
The version I'm using is; GIT P3Dv4 64Bit
rgds
Daniel Gamboa
The 32bit version of GIT for P3Dv4 is GIT P3Dv4.zip. It should show up in your account profile.
Do I have to pay for the 32 bit version?
rgds
Daniel Gamboa
rgds
I download the zip file but it doesn't open, why? I do not know. Now I went to My Profile to try again and my downloads options are 0.
rgds
Daniel Gamboa
Please disregard my previous message, now I have the file open and installed but nothing changed. I can see the numbers and move the knobs but the same as before.. The only thing new is that if a click the keys; ALT HLD - APP-HDG, the F/D gos on.
I'll keep you posted.
rgds
Daniel Gamboa
I checked the FAQ all over again and deleted all the files in this carpet: AppData\Local\PollyPot_Software, but it´s the same as before, the GF MCP is not in parallel with the PMDG MCP.
rgds
Daniel Gamboa
rgds
Daniel Gamboa
I reinstalled the flight sim and now the MCP is working but very erratic, if you try to stablish a heading or altitude, all the numbers go up and down, and you can't get the ones you want.
rgds
Daniel Gamboa
Have you forgotten to set the MCP PRO to compatible add-on in GFConfig?
Yes, I forgot it. Now all is working ok.
Thanks for all your suport.
Rgds
Daniel Gamboa
