Purchase
I'm having trouble with your website in posting a question?
Bill Clark
Bill Clark
I assume I get the basic GoFlight Driver from GoFlight?
Bill Clark
No. The 32bit version works will all Simconnect based flight sims including P3Dv4. There is a 64bit version for P3Dv4 as well.
The basic drivers from GoFlight support fully simconnect compliant aircraft, so it won't provide PMDG support for example.
I will pick up the 32-bit version of GIT for P3D v4.3.
Bill Clark
I tried to purchase and I got this message:
Your IP address has been blocked because there were too many unsuccessful login attempts in a short time. Your IP address is:xxxxxxxxxx
Bill Clark
It sounds like you are trying to login without an account. You can create an account during the checkout process once you have added GIT to your basket/cart.
Email already in use. Try with another email or login by going to previous step
I only have one email address...........I would post it here but then I would make it public.
Bill Clark
I have found you in the system and you have already bought GIT, so you can download the 64Bit version without purchasing it.
If you have forgotten your password, there is a password reset facility at the bottom of the login screen. I will PM you your login name.
Bill
