EFIS Works bur MCP PRO Shows all Dashes?
I have both the EFIS and MCP Pro Installed.
I've installed the GoFlight Configuration Tool and GIT properly.
When I launch P3D V4.3, the EFIS works fine, but my MCP Pro is displaying all "Dashes." Also none of the buttons or switches work on the MCP Pro either.
I know the GoFlight Interface Module is being launched, as when the default A/C shows up (The Extra 300 Sport Plane) then the led segments show up as all "dashes." At this time I launch the GIT.exe shortcut from the desktop. I then select the PMDG 777, and launch the sim to watch the Virtual Cockpit of the 777 appear.
All the lights are green on the GIT with the Green light under the 777 A/C on the GIT is blinking rapidly.
I followed all the 8 steps in your FAQ if you get dashes and nothing I have tried so far has worked.
Bill Clark
  • Steve,
    Should the .NET Framework show up in the Program and Features section of the Control Panel?
    BTW, I am running Windows 10.
    Bill Clark
  • Hi Bill,
    Have you enabled the MCP PRO in GIT?
  • Steve,
    In the past I never had to do that.
    How do you enable?
    Bill Clark
  • Hi Bill,
    On the MCP PRO tab, click the combo box and select "Device 0". This will enable the device state combo box where you can pick ENABLED. Once you have done this, quit GIT and then restart it and it should spring into life!
  • Thanks Steve,
    I figured that out yesterday..........found it on your site.
    It seems to be working ok with the PMDG 737, 747, and 777.
    I would suggest you include this info in the FAQ that addresses if you get all "dashes." as I spent a long time attempting to determine what I did wrong. Last time I used your software a while back, this additional configuration step was not required as I recall.
    Bill Clark
