NOTHING WORKED!
I did everything possible but still my goflight products doesnt work with GIT i unintalled p3d and reinstalled but didnt work then i formatted windows installed p3d than installed only pmdg fsuipc and gf2.28 and git p3dv4 but still nothing work its been 6 months still cant use my 1000$ goflight equipments admin please help me!! i always get the same error!!
23:04:20 GoFlight Connection Starting.....
23:04:20 SimConnect Connection Starting.....
23:04:20 SimConnect Message Processing Started
23:04:21 GoFlight Connection Started
23:04:21 SimConnect Connection Started
23:04:21 Aircraft Connection Starting.....
23:04:21 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:04:21 SimConnect: Event Received: SIM, 0
23:04:21 SimConnect: Event Received: PAUSE, 0
23:04:23 WinSock: Connected To localhost On Port 27015!
23:04:23 LUA Processor: Started!
23:04:25 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
23:04:25 Aircraft Connection Started
23:04:25 Simconnect Version: 3.4.0.0
23:04:25 Aircraft FullName: ed Martin
23:04:25 Synchronising Switches & Selectors .....
23:04:25 Synchronising Switches & Selectors: Waiting for SimConnect .....
23:04:53 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:05:28 SimConnect: Event Received: SIMSTART, 0
23:05:28 SimConnect: Event Received: SIM, 1
23:05:34 LvarNamesUpdated!
23:05:34 Creating Bespoke Vars
23:05:34 Bespoke Vars Created
23:05:34 Importing Bespoke Variables
23:05:34 Bespoke Vars Assigned, Importing Bespoke Events
23:05:34 Bespoke Events Temp Imported
23:05:34 Bespoke Events Imported
23:05:34 Loading Aircraft Settings
23:05:34 GetXMLConfigData
23:05:34 GotXMLConfigData
23:05:34 Loading Power
23:05:34 Loading MCPPRO
23:05:34 Loading EFIS
23:05:34 Loading P8
23:05:34 Loading T8
23:05:34 Loading RP48
23:05:34 Loading MESM
23:05:34 Loading WP6
23:05:34 Loading LGT
23:05:34 Loading LGT II
23:05:34 Loading GF46
23:05:34 Loading GF45
23:05:34 Loading TQ6
23:05:34 Loading DIO
23:05:34 Loading GF166
23:05:34 Loading SECM
23:05:34 Loading Joysticks
23:05:34 Clearing Displays
23:05:34 Reset Data
23:05:34 Aircraft Settings Loaded
23:05:34 Calling Aircraft Changed
23:05:35 Aircraft Changed
23:05:35 LvarNamesUpdated!
23:05:35 Creating Bespoke Vars
23:05:35 Bespoke Vars Created
23:05:35 Importing Bespoke Variables
23:05:35 Bespoke Vars Assigned, Importing Bespoke Events
23:05:35 Bespoke Events Temp Imported
23:05:35 Bespoke Events Imported
23:05:35 Loading Aircraft Settings
23:05:35 GetXMLConfigData
23:05:35 GotXMLConfigData
23:05:35 Loading Power
23:05:35 Loading MCPPRO
23:05:35 Loading EFIS
23:05:35 Loading P8
23:05:35 Loading T8
23:05:35 Loading RP48
23:05:35 Loading MESM
23:05:35 Loading WP6
23:05:35 Loading LGT
23:05:35 Loading LGT II
23:05:35 Loading GF46
23:05:35 Loading GF45
23:05:35 Loading TQ6
23:05:35 Loading DIO
23:05:35 Loading GF166
23:05:35 Loading SECM
23:05:35 Loading Joysticks
23:05:35 Clearing Displays
23:05:35 Reset Data
23:05:35 Aircraft Settings Loaded
23:05:35 Calling Aircraft Changed
23:05:37 Synchronising Switches & Selectors Complete
  • there is no lua pmdg on goflight interface folder that is located on my documents
  • The log file looks fine. Not sure if the aircraft name "ed Martin" is correct? Have you configured the devices in GIT and enabled them? GIT won't just work unless its PMDG/iFly aircraft - it must be configured.
  • edited October 2018
    i cannot configure when i install default f22 and then change it to pmdg for 5 seconds it recognise the pmdg aircraft then turn to "ed martin". I tried to change the name from settings it didnt worked.
  • I'm guessing the "ed Martin" is Lockheed Martin truncated. Not sure what is happening; I have never seen this behaviour before.
    Can you try the using the non 64bit version of GIT for P3Dv4 - its called GIT P3Dv4.zip and see if the same behaviour occurs.
    Note that you must be running the very latest version of PMDG NGX aircraft as GIT will not work with older versions.
    If it still occurs, post the whole log from starting GIT including switching over to the NGX. Also note the LED status on the Status tab when "ed Martin" appears. Also give me the versions of P3Dv4, NGX and GIT.
  • I am using the latest version of PMDG ngx and P3D i just installed GIT 32 bit but there is still the same proble "ed martin" mcp is displaying all 0 when i turn the knobs still 0.
    15:24:26 GoFlight Connection Starting.....
    15:24:26 SimConnect Connection Starting.....
    15:24:27 SimConnect Message Processing Started
    15:24:27 GoFlight Connection Started
    15:24:27 SimConnect Connection Started
    15:24:27 Aircraft Connection Starting.....
    15:24:27 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    15:24:27 SimConnect: Event Received: SIM, 1
    15:24:27 SimConnect: Event Received: PAUSE, 0
    15:24:29 WinSock: Connected To localhost On Port 27015!
    15:24:29 LUA Processor: Started!
    15:24:31 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
    15:24:31 Aircraft Connection Started
    15:24:31 Simconnect Version: 3.4.0.0
    15:24:31 Aircraft FullName: ed Martin
    15:24:31 Synchronising Switches & Selectors .....
    15:24:31 LvarNamesUpdated!
    15:24:31 Creating Bespoke Vars
    15:24:31 Bespoke Vars Created
    15:24:31 Importing Bespoke Variables
    15:24:31 Bespoke Vars Assigned, Importing Bespoke Events
    15:24:31 Bespoke Events Temp Imported
    15:24:31 Bespoke Events Imported
    15:24:31 Loading Aircraft Settings
    15:24:31 GetXMLConfigData
    15:24:31 GotXMLConfigData
    15:24:31 Loading Power
    15:24:31 Loading MCPPRO
    15:24:32 Loading MCP
    15:24:32 Loading EFIS
    15:24:32 Loading P8
    15:24:32 Loading T8
    15:24:32 Loading RP48
    15:24:32 Loading MESM
    15:24:32 Loading WP6
    15:24:32 Loading LGT
    15:24:32 Loading LGT II
    15:24:32 Loading GF46
    15:24:32 Loading GF45
    15:24:32 Loading TQ6
    15:24:32 Loading DIO
    15:24:32 Loading GF166
    15:24:32 Loading SECM
    15:24:32 Loading Joysticks
    15:24:32 Clearing Displays
    15:24:32 Reset Data
    15:24:32 Aircraft Settings Loaded
    15:24:32 Calling Aircraft Changed
    15:24:32 Aircraft Changed
    15:24:32 LvarNamesUpdated!
    15:24:32 Creating Bespoke Vars
    15:24:32 Bespoke Vars Created
    15:24:32 Importing Bespoke Variables
    15:24:32 Bespoke Vars Assigned, Importing Bespoke Events
    15:24:32 Bespoke Events Temp Imported
    15:24:32 Bespoke Events Imported
    15:24:32 Loading Aircraft Settings
    15:24:32 GetXMLConfigData
    15:24:32 GotXMLConfigData
    15:24:32 Loading Power
    15:24:32 Loading MCPPRO
    15:24:32 Loading P8
    15:24:32 Loading T8
    15:24:32 Reset Data
    15:24:34 Synchronising Switches & Selectors Complete
  • I need the log from the start up of GIT up to you seeing the Virtual Cockpit of the NGX. It must show two aircraft name changes in the log.
    This is the log from the start with pmdg 737ngx.. can you please reset my account i cant activate git!
    16:49:28 GoFlight Connection Starting.....
    16:49:28 SimConnect Connection Starting.....
    16:49:28 SimConnect Message Processing Started
    16:49:28 GoFlight Connection Started
    16:49:29 SimConnect Connection Started
    16:49:29 Aircraft Connection Starting.....
    16:49:29 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    16:49:29 SimConnect: Event Received: SIM, 1
    16:49:29 SimConnect: Event Received: PAUSE, 0
    16:49:31 WinSock: Connected To localhost On Port 27015!
    16:49:31 LUA Processor: Started!
    16:49:33 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
    16:49:33 Aircraft Connection Started
    16:49:33 Simconnect Version: 3.4.0.0
    16:49:33 Aircraft FullName: ed Martin
    16:49:33 Synchronising Switches & Selectors .....
    16:49:33 LvarNamesUpdated!
    16:49:33 Creating Bespoke Vars
    16:49:33 Bespoke Vars Created
    16:49:33 Importing Bespoke Variables
    16:49:33 Bespoke Vars Assigned, Importing Bespoke Events
    16:49:33 Bespoke Events Temp Imported
    16:49:33 Bespoke Events Imported
    16:49:33 Loading Aircraft Settings
    16:49:33 GetXMLConfigData
    16:49:33 GotXMLConfigData
    16:49:33 Loading Power
    16:49:33 Loading MCPPRO
    16:49:33 Loading EFIS
    16:49:33 Loading P8
    16:49:33 Loading T8
    16:49:33 Loading RP48
    16:49:33 Loading MESM
    16:49:33 Loading WP6
    16:49:33 Loading LGT
    16:49:33 Loading LGT II
    16:49:33 Loading GF46
    16:49:33 Loading GF45
    16:49:33 Loading TQ6
    16:49:33 Loading DIO
    16:49:33 Loading GF166
    16:49:33 Loading SECM
    16:49:33 Loading Joysticks
    16:49:33 Clearing Displays
    16:49:33 Reset Data
    16:49:33 Aircraft Settings Loaded
    16:49:33 Calling Aircraft Changed
    16:49:34 Aircraft Changed
    16:49:34 LvarNamesUpdated!
    16:49:34 Creating Bespoke Vars
    16:49:34 Bespoke Vars Created
    16:49:34 Importing Bespoke Variables
    16:49:34 Bespoke Vars Assigned, Importing Bespoke Events
    16:49:34 Bespoke Events Temp Imported
    16:49:34 Bespoke Events Imported
    16:49:34 Loading Aircraft Settings
    16:49:34 GetXMLConfigData
    16:49:34 GotXMLConfigData
    16:49:34 Loading Power
    16:49:34 Loading MCPPRO
    16:49:34 Loading EFIS
    16:49:34 Loading P8
    16:49:34 Loading T8
    16:49:34 Loading RP48
    16:49:34 Loading MESM
    16:49:34 Loading WP6
    16:49:34 Loading LGT
    16:49:34 Loading LGT II
    16:49:34 Loading GF46
    16:49:34 Loading GF45
    16:49:34 Loading TQ6
    16:49:34 Loading DIO
    16:49:34 Loading GF166
    16:49:34 Loading SECM
    16:49:34 Loading Joysticks
    16:49:34 Clearing Displays
    16:49:34 Reset Data
    16:49:34 Aircraft Settings Loaded
    16:49:34 Calling Aircraft Changed
    16:49:36 Synchronising Switches & Selectors Complete
  • This log is still not complete. The easiest thing to do is to right click on the GIT icon and select properties. In the Target field add /log at the end making sure you leave a space between " and /
    This will produce a log file in Documents\GoFlight Interface Tool called log.txt. Simple attach that file to this discussion when you have the NGX showing the Virtual Cockpit.
  • i did exactly as you described.. Cn you please reset my account so i dont get 202 message.
    17:15:01 GoFlight Connection Starting.....
    17:15:01 SimConnect Connection Starting.....
    17:15:02 SimConnect Message Processing Started
    17:15:02 GoFlight Connection Started
    17:15:02 SimConnect Connection Started
    17:15:02 Aircraft Connection Starting.....
    17:15:02 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    17:15:02 SimConnect: Event Received: SIM, 1
    17:15:02 SimConnect: Event Received: PAUSE, 0
    17:15:04 WinSock: Connected To localhost On Port 27015!
    17:15:04 LUA Processor: Started!
    17:15:06 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
    17:15:06 Aircraft Connection Started
    17:15:06 Simconnect Version: 3.4.0.0
    17:15:06 Aircraft FullName: ed Martin
    17:15:06 Synchronising Switches & Selectors .....
    17:15:06 LvarNamesUpdated!
    17:15:06 Creating Bespoke Vars
    17:15:06 Bespoke Vars Created
    17:15:06 Importing Bespoke Variables
    17:15:06 Bespoke Vars Assigned, Importing Bespoke Events
    17:15:06 Bespoke Events Temp Imported
    17:15:06 Bespoke Events Imported
    17:15:06 Loading Aircraft Settings
    17:15:06 GetXMLConfigData
    17:15:06 GotXMLConfigData
    17:15:06 Loading Power
    17:15:06 Loading MCPPRO
    17:15:07 Loading MCP
    17:15:07 Loading EFIS
    17:15:07 Loading P8
    17:15:07 Loading T8
    17:15:07 Loading RP48
    17:15:07 Loading MESM
    17:15:07 Loading WP6
    17:15:07 Loading LGT
    17:15:07 Loading LGT II
    17:15:07 Loading GF46
    17:15:07 Loading GF45
    17:15:07 Loading TQ6
    17:15:07 Loading DIO
    17:15:07 Loading GF166
    17:15:07 Loading SECM
    17:15:07 Loading Joysticks
    17:15:07 Clearing Displays
    17:15:07 Reset Data
    17:15:07 Aircraft Settings Loaded
    17:15:07 Calling Aircraft Changed
    17:15:07 Aircraft Changed
    17:15:07 LvarNamesUpdated!
    17:15:07 Creating Bespoke Vars
    17:15:07 Bespoke Vars Created
    17:15:07 Importing Bespoke Variables
    17:15:08 Bespoke Vars Assigned, Importing Bespoke Events
    17:15:08 Bespoke Events Temp Imported
    17:15:08 Bespoke Events Imported
    17:15:08 Loading Aircraft Settings
    17:15:08 GetXMLConfigData
    17:15:08 GotXMLConfigData
    17:15:08 Loading Power
    17:15:08 Loading MCPPRO
    17:15:08 Loading EFIS
    17:15:08 Loading P8
    17:15:08 Loading T8
    17:15:08 Loading RP48
    17:15:08 Loading MESM
    17:15:08 Loading WP6
    17:15:08 Loading LGT
    17:15:08 Loading LGT II
    17:15:08 Loading GF46
    17:15:08 Loading GF45
    17:15:08 Loading TQ6
    17:15:08 Loading DIO
    17:15:08 Loading GF166
    17:15:08 Loading SECM
    17:15:08 Loading Joysticks
    17:15:08 Clearing Displays
    17:15:08 Reset Data
    17:15:08 Aircraft Settings Loaded
    17:15:08 Calling Aircraft Changed
    17:15:08 Aircraft Changed
    17:15:09 Synchronising Switches & Selectors Complete
    17:16:42 SimConnect: Event Received: SIMSTOP, 0
    17:16:42 SimConnect: Event Received: SIM, 0
    17:16:59 SimConnect: Event Received: Quit
    17:16:59 SimConnect Message Processing Finished
    17:17:00 SimConnect Connection Starting.....
    OK, in My Documents\Prepar3D v4 Files, edit or create Simconnect.ini and change the entries as follows:
    [SimConnect]
    level=verbose
    console=1
    Start P3D and a Cmd window will appear. Once P3D is at the menu screen, select the NGX and mark all the contents in the Cmd window (right click in the Cmd window, click on the very last line end character and then move the mouse so it highlights up to the beginning of the all text and then press enter). Now paste into a text file and attach on this thread.
  • here is the dos text
    cmd.txt 396.1K
  • I thought this was a clean installation - that file shows loads of add-ons being loaded which is not going to help diagnosis.
    The file also shows no PMDG dll files being loaded. This does suggest a faulty NGX installation because when comparing your output with mine, with just the F22 raptor loaded, I have lots of PMDG entries.
    Uninstall and reinstall the latest version of the NGX, then test. If you still have the same problems, take a backup of dll.xml and exe.xml (they are in Users\your name\AppData\Roaming\Lockheed Martin\Prepar3D v4. Then delete exe.xml and alter dll.xml so it only contains the GoFlight Interface Module entry e.g. something like:
    <SimBase.Document Type="Launch" version="1,0">
      <Descr>Launch</Descr>
      <Filename>dll.xml</Filename>
      <Disabled>False</Disabled>
      <Launch.ManualLoad>False</Launch.ManualLoad>
      <Launch.Addon>
        <Name>GoFlight Interface Module</Name>
        <Path>C:\Program Files\GoFlight\GoFlight Interface Module 64.dll</Path>
      </Launch.Addon>
    </SimBase.Document>
    Then test again. If the problem persists, attach another cmd.txt file with the changes above still in place.
    i uninstalled and reinstalled pmdg737ngx i had no luck than i deleted the exe file and just copied the text that you sent me in dll file and tried but still same problem here is the cmd file
  • The file is empty.
  • sorry! here it is..
    cmd.txt 55.5K
  • There are still no PMDG DLL loading entires in that log, but all the GIT stuff is firing up fine.
    Since no-one else has this problem with GIT and the aircraft name is provided by Simconnect to GIT, I can only assume that some add-on is interfering with your flight sim or your Simconnect/flight sim installation is broken in some way.
    I think the best course of action is to wipe your system and start with a clean install of Windows 10, P3Dv4, the NGX and GIT only and take it from there.
