NOTHING WORKED!
I did everything possible but still my goflight products doesnt work with GIT i unintalled p3d and reinstalled but didnt work then i formatted windows installed p3d than installed only pmdg fsuipc and gf2.28 and git p3dv4 but still nothing work its been 6 months still cant use my 1000$ goflight equipments admin please help me!! i always get the same error!!
23:04:20 GoFlight Connection Starting.....
23:04:20 SimConnect Connection Starting.....
23:04:20 SimConnect Message Processing Started
23:04:21 GoFlight Connection Started
23:04:21 SimConnect Connection Started
23:04:21 Aircraft Connection Starting.....
23:04:21 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:04:21 SimConnect: Event Received: SIM, 0
23:04:21 SimConnect: Event Received: PAUSE, 0
23:04:23 WinSock: Connected To localhost On Port 27015!
23:04:23 LUA Processor: Started!
23:04:25 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
23:04:25 Aircraft Connection Started
23:04:25 Simconnect Version: 3.4.0.0
23:04:25 Aircraft FullName: ed Martin
23:04:25 Synchronising Switches & Selectors .....
23:04:25 Synchronising Switches & Selectors: Waiting for SimConnect .....
23:04:53 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:05:28 SimConnect: Event Received: SIMSTART, 0
23:05:28 SimConnect: Event Received: SIM, 1
23:05:34 LvarNamesUpdated!
23:05:34 Creating Bespoke Vars
23:05:34 Bespoke Vars Created
23:05:34 Importing Bespoke Variables
23:05:34 Bespoke Vars Assigned, Importing Bespoke Events
23:05:34 Bespoke Events Temp Imported
23:05:34 Bespoke Events Imported
23:05:34 Loading Aircraft Settings
23:05:34 GetXMLConfigData
23:05:34 GotXMLConfigData
23:05:34 Loading Power
23:05:34 Loading MCPPRO
23:05:34 Loading EFIS
23:05:34 Loading P8
23:05:34 Loading T8
23:05:34 Loading RP48
23:05:34 Loading MESM
23:05:34 Loading WP6
23:05:34 Loading LGT
23:05:34 Loading LGT II
23:05:34 Loading GF46
23:05:34 Loading GF45
23:05:34 Loading TQ6
23:05:34 Loading DIO
23:05:34 Loading GF166
23:05:34 Loading SECM
23:05:34 Loading Joysticks
23:05:34 Clearing Displays
23:05:34 Reset Data
23:05:34 Aircraft Settings Loaded
23:05:34 Calling Aircraft Changed
23:05:35 Aircraft Changed
23:05:35 LvarNamesUpdated!
23:05:35 Creating Bespoke Vars
23:05:35 Bespoke Vars Created
23:05:35 Importing Bespoke Variables
23:05:35 Bespoke Vars Assigned, Importing Bespoke Events
23:05:35 Bespoke Events Temp Imported
23:05:35 Bespoke Events Imported
23:05:35 Loading Aircraft Settings
23:05:35 GetXMLConfigData
23:05:35 GotXMLConfigData
23:05:35 Loading Power
23:05:35 Loading MCPPRO
23:05:35 Loading EFIS
23:05:35 Loading P8
23:05:35 Loading T8
23:05:35 Loading RP48
23:05:35 Loading MESM
23:05:35 Loading WP6
23:05:35 Loading LGT
23:05:35 Loading LGT II
23:05:35 Loading GF46
23:05:35 Loading GF45
23:05:35 Loading TQ6
23:05:35 Loading DIO
23:05:35 Loading GF166
23:05:35 Loading SECM
23:05:35 Loading Joysticks
23:05:35 Clearing Displays
23:05:35 Reset Data
23:05:35 Aircraft Settings Loaded
23:05:35 Calling Aircraft Changed
23:05:37 Synchronising Switches & Selectors Complete
23:05:34 Loading P8
23:05:34 Loading T8
23:05:34 Reset Data
23:05:35 Loading P8
23:05:35 Loading T8
23:05:35 Reset Data
Can you try the using the non 64bit version of GIT for P3Dv4 - its called GIT P3Dv4.zip and see if the same behaviour occurs.
Note that you must be running the very latest version of PMDG NGX aircraft as GIT will not work with older versions.
If it still occurs, post the whole log from starting GIT including switching over to the NGX. Also note the LED status on the Status tab when "ed Martin" appears. Also give me the versions of P3Dv4, NGX and GIT.
15:24:26 GoFlight Connection Starting.....
15:24:26 SimConnect Connection Starting.....
15:24:27 SimConnect Message Processing Started
15:24:27 GoFlight Connection Started
15:24:27 SimConnect Connection Started
15:24:27 Aircraft Connection Starting.....
15:24:27 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
15:24:27 SimConnect: Event Received: SIM, 1
15:24:27 SimConnect: Event Received: PAUSE, 0
15:24:29 WinSock: Connected To localhost On Port 27015!
15:24:29 LUA Processor: Started!
15:24:31 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
15:24:31 Aircraft Connection Started
15:24:31 Simconnect Version: 3.4.0.0
15:24:31 Aircraft FullName: ed Martin
15:24:31 Synchronising Switches & Selectors .....
15:24:31 LvarNamesUpdated!
15:24:31 Creating Bespoke Vars
15:24:31 Bespoke Vars Created
15:24:31 Importing Bespoke Variables
15:24:31 Bespoke Vars Assigned, Importing Bespoke Events
15:24:31 Bespoke Events Temp Imported
15:24:31 Bespoke Events Imported
15:24:31 Loading Aircraft Settings
15:24:31 GetXMLConfigData
15:24:31 GotXMLConfigData
15:24:31 Loading Power
15:24:31 Loading MCPPRO
15:24:32 Loading MCP
15:24:32 Loading EFIS
15:24:32 Loading P8
15:24:32 Loading T8
15:24:32 Loading RP48
15:24:32 Loading MESM
15:24:32 Loading WP6
15:24:32 Loading LGT
15:24:32 Loading LGT II
15:24:32 Loading GF46
15:24:32 Loading GF45
15:24:32 Loading TQ6
15:24:32 Loading DIO
15:24:32 Loading GF166
15:24:32 Loading SECM
15:24:32 Loading Joysticks
15:24:32 Clearing Displays
15:24:32 Reset Data
15:24:32 Aircraft Settings Loaded
15:24:32 Calling Aircraft Changed
15:24:32 Aircraft Changed
15:24:32 LvarNamesUpdated!
15:24:32 Creating Bespoke Vars
15:24:32 Bespoke Vars Created
15:24:32 Importing Bespoke Variables
15:24:32 Bespoke Vars Assigned, Importing Bespoke Events
15:24:32 Bespoke Events Temp Imported
15:24:32 Bespoke Events Imported
15:24:32 Loading Aircraft Settings
15:24:32 GetXMLConfigData
15:24:32 GotXMLConfigData
15:24:32 Loading Power
15:24:32 Loading MCPPRO
15:24:32 Loading P8
15:24:32 Loading T8
15:24:32 Reset Data
15:24:34 Synchronising Switches & Selectors Complete
16:49:28 GoFlight Connection Starting.....
16:49:28 SimConnect Connection Starting.....
16:49:28 SimConnect Message Processing Started
16:49:28 GoFlight Connection Started
16:49:29 SimConnect Connection Started
16:49:29 Aircraft Connection Starting.....
16:49:29 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:49:29 SimConnect: Event Received: SIM, 1
16:49:29 SimConnect: Event Received: PAUSE, 0
16:49:31 WinSock: Connected To localhost On Port 27015!
16:49:31 LUA Processor: Started!
16:49:33 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
16:49:33 Aircraft Connection Started
16:49:33 Simconnect Version: 3.4.0.0
16:49:33 Aircraft FullName: ed Martin
16:49:33 Synchronising Switches & Selectors .....
16:49:33 LvarNamesUpdated!
16:49:33 Creating Bespoke Vars
16:49:33 Bespoke Vars Created
16:49:33 Importing Bespoke Variables
16:49:33 Bespoke Vars Assigned, Importing Bespoke Events
16:49:33 Bespoke Events Temp Imported
16:49:33 Bespoke Events Imported
16:49:33 Loading Aircraft Settings
16:49:33 GetXMLConfigData
16:49:33 GotXMLConfigData
16:49:33 Loading Power
16:49:33 Loading MCPPRO
16:49:33 Loading EFIS
16:49:33 Loading P8
16:49:33 Loading T8
16:49:33 Loading RP48
16:49:33 Loading MESM
16:49:33 Loading WP6
16:49:33 Loading LGT
16:49:33 Loading LGT II
16:49:33 Loading GF46
16:49:33 Loading GF45
16:49:33 Loading TQ6
16:49:33 Loading DIO
16:49:33 Loading GF166
16:49:33 Loading SECM
16:49:33 Loading Joysticks
16:49:33 Clearing Displays
16:49:33 Reset Data
16:49:33 Aircraft Settings Loaded
16:49:33 Calling Aircraft Changed
16:49:34 Aircraft Changed
16:49:34 LvarNamesUpdated!
16:49:34 Creating Bespoke Vars
16:49:34 Bespoke Vars Created
16:49:34 Importing Bespoke Variables
16:49:34 Bespoke Vars Assigned, Importing Bespoke Events
16:49:34 Bespoke Events Temp Imported
16:49:34 Bespoke Events Imported
16:49:34 Loading Aircraft Settings
16:49:34 GetXMLConfigData
16:49:34 GotXMLConfigData
16:49:34 Loading Power
16:49:34 Loading MCPPRO
16:49:34 Loading EFIS
16:49:34 Loading P8
16:49:34 Loading T8
16:49:34 Loading RP48
16:49:34 Loading MESM
16:49:34 Loading WP6
16:49:34 Loading LGT
16:49:34 Loading LGT II
16:49:34 Loading GF46
16:49:34 Loading GF45
16:49:34 Loading TQ6
16:49:34 Loading DIO
16:49:34 Loading GF166
16:49:34 Loading SECM
16:49:34 Loading Joysticks
16:49:34 Clearing Displays
16:49:34 Reset Data
16:49:34 Aircraft Settings Loaded
16:49:34 Calling Aircraft Changed
16:49:36 Synchronising Switches & Selectors Complete
This will produce a log file in Documents\GoFlight Interface Tool called log.txt. Simple attach that file to this discussion when you have the NGX showing the Virtual Cockpit.
17:15:01 GoFlight Connection Starting.....
17:15:01 SimConnect Connection Starting.....
17:15:02 SimConnect Message Processing Started
17:15:02 GoFlight Connection Started
17:15:02 SimConnect Connection Started
17:15:02 Aircraft Connection Starting.....
17:15:02 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:15:02 SimConnect: Event Received: SIM, 1
17:15:02 SimConnect: Event Received: PAUSE, 0
17:15:04 WinSock: Connected To localhost On Port 27015!
17:15:04 LUA Processor: Started!
17:15:06 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
17:15:06 Aircraft Connection Started
17:15:06 Simconnect Version: 3.4.0.0
17:15:06 Aircraft FullName: ed Martin
17:15:06 Synchronising Switches & Selectors .....
17:15:06 LvarNamesUpdated!
17:15:06 Creating Bespoke Vars
17:15:06 Bespoke Vars Created
17:15:06 Importing Bespoke Variables
17:15:06 Bespoke Vars Assigned, Importing Bespoke Events
17:15:06 Bespoke Events Temp Imported
17:15:06 Bespoke Events Imported
17:15:06 Loading Aircraft Settings
17:15:06 GetXMLConfigData
17:15:06 GotXMLConfigData
17:15:06 Loading Power
17:15:06 Loading MCPPRO
17:15:07 Loading MCP
17:15:07 Loading EFIS
17:15:07 Loading P8
17:15:07 Loading T8
17:15:07 Loading RP48
17:15:07 Loading MESM
17:15:07 Loading WP6
17:15:07 Loading LGT
17:15:07 Loading LGT II
17:15:07 Loading GF46
17:15:07 Loading GF45
17:15:07 Loading TQ6
17:15:07 Loading DIO
17:15:07 Loading GF166
17:15:07 Loading SECM
17:15:07 Loading Joysticks
17:15:07 Clearing Displays
17:15:07 Reset Data
17:15:07 Aircraft Settings Loaded
17:15:07 Calling Aircraft Changed
17:15:07 Aircraft Changed
17:15:07 LvarNamesUpdated!
17:15:07 Creating Bespoke Vars
17:15:07 Bespoke Vars Created
17:15:07 Importing Bespoke Variables
17:15:08 Bespoke Vars Assigned, Importing Bespoke Events
17:15:08 Bespoke Events Temp Imported
17:15:08 Bespoke Events Imported
17:15:08 Loading Aircraft Settings
17:15:08 GetXMLConfigData
17:15:08 GotXMLConfigData
17:15:08 Loading Power
17:15:08 Loading MCPPRO
17:15:08 Loading EFIS
17:15:08 Loading P8
17:15:08 Loading T8
17:15:08 Loading RP48
17:15:08 Loading MESM
17:15:08 Loading WP6
17:15:08 Loading LGT
17:15:08 Loading LGT II
17:15:08 Loading GF46
17:15:08 Loading GF45
17:15:08 Loading TQ6
17:15:08 Loading DIO
17:15:08 Loading GF166
17:15:08 Loading SECM
17:15:08 Loading Joysticks
17:15:08 Clearing Displays
17:15:08 Reset Data
17:15:08 Aircraft Settings Loaded
17:15:08 Calling Aircraft Changed
17:15:08 Aircraft Changed
17:15:09 Synchronising Switches & Selectors Complete
17:16:42 SimConnect: Event Received: SIMSTOP, 0
17:16:42 SimConnect: Event Received: SIM, 0
17:16:59 SimConnect: Event Received: Quit
17:16:59 SimConnect Message Processing Finished
17:17:00 SimConnect Connection Starting.....
[SimConnect]
level=verbose
console=1
Start P3D and a Cmd window will appear. Once P3D is at the menu screen, select the NGX and mark all the contents in the Cmd window (right click in the Cmd window, click on the very last line end character and then move the mouse so it highlights up to the beginning of the all text and then press enter). Now paste into a text file and attach on this thread.
The file also shows no PMDG dll files being loaded. This does suggest a faulty NGX installation because when comparing your output with mine, with just the F22 raptor loaded, I have lots of PMDG entries.
Uninstall and reinstall the latest version of the NGX, then test. If you still have the same problems, take a backup of dll.xml and exe.xml (they are in Users\your name\AppData\Roaming\Lockheed Martin\Prepar3D v4. Then delete exe.xml and alter dll.xml so it only contains the GoFlight Interface Module entry e.g. something like: Then test again. If the problem persists, attach another cmd.txt file with the changes above still in place.
Since no-one else has this problem with GIT and the aircraft name is provided by Simconnect to GIT, I can only assume that some add-on is interfering with your flight sim or your Simconnect/flight sim installation is broken in some way.
I think the best course of action is to wipe your system and start with a clean install of Windows 10, P3Dv4, the NGX and GIT only and take it from there.
