GF-45
GF-45 will not work in Xplane..it worked before..have tried GF windows fixer..any other suggestions? It works if P3d.thx
  • I'll need to test and come back to you.
  • Thank you Steve..Suggestions please. I have worked countless hours on my goflight modules. Here is where I am at after latest download of my GIT for Xplane11.Original download was on 1/20/2017. I have 7 units total. SECM,GF-45,GF-TPM,GF-P8, all seem to work ok. Problems are as follow: 1. GF-LGT 2 has no gear lights and gear selector lever does not work, flaps lever does work.2. GF-ATC does not work at all, I do realize it currently is not supported. 3. GF-166a number display lights do not work although Ident works on the two green lights, but it does change the freq on aircraft panel. * at one time these all worked with exception of GF-ATC. Appeared to run into problems after downloading LATEST GIT?...Is it a must that I download a config file and download to GIF? I only want the default C172 to fuction at this time. It must something simple I am MISSING? **BTW, all modules work correct in P3d althought I only use the GF interface. All suggestions greatly appreciated! Roger
  • Have a read of this post: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1010/gf-166-and-gf-46-lighting-up#latest
    Anything with Displays has enhanced power management features enabled by default
    Cheers
    Lee
  • also to ensure that the panel is woke up I have something like the Barometer setting as my 1st and use the Rotary to Set it
