P3D V4 Crashes when GIT Initialises
I hope you can help me here. For no obvious reason whenever I load up the PMDG 737NGX with GIT in P3D V4.3, P3D crashes as soon as GIT starts to initialise all the various devices - by that I mean the aircraft has loaded, PMDG is still completing its initialisation countdown and GIT kicks in to initialise the switch settings etc during which time, poof, P3D just disappears. No messages, no logs and no Windows Events to look at, absolutely nothing. If I load up P3D without GIT running then all is fine until I fire up GIT at which point I get exactly the same problem. I have tried reinstalling GIT, deleting the appcompatflags/layers registry entry and the PMDG 777 as I saw these mentioned on a similar problem as possible causes, but to no avail for me.
Any ideas please?
Neil
Any ideas please?
Neil
Assuming it used to work and this has suddenly happened, I would try renaming Documents\GoFlight Interface Tool so GIT starts with a wiped config. If that works OK, try enabling some devices that autoconfigure such as the MCP PRO, then quit GIT and start GIT again.
If all is OK at this point, it indicates a corrupt PMDG settings file. You can then undo the renaming of the directory and either delete PMDG.xml or attempt to identify and remove the corrupt data in PMDG.xml
Thanks, that seems to have worked. I renamed that folder and all was fine and I have since re-imported all devices with no issues so far.
Neil
