New GIT and P3dV4.4
Hi
Loaded new GIT (64bit). Now won't talk to P3DV4.4 (64bit)...any clues from anyone?
Loading GIT just continues and must be closed with Task Mgr
  • Have you installed GIT in the same directory as the GoFlight drivers as it needs to access GFDev.dll?
  • Hello, could it be that goflight has a problem with prepar3d 4.4? After installing the new Client, everything seems to be ok. But after installing the content 4.4 my goflight modules are not working as they should. Sadly I get no answer from goflight since last saturday. Dont know, if they are sill in business.
    Best regards
    phecht
  • Lets try starting with a clean config by renaming Documents\GoFlight Interface Tool to something else, then starting GIT.
