Zibo 737 - MCP Pro - not all lights work
Most specifically the LNAV and VNAV don't light up. They engage in the cockpit, they just don't light up on the hardware. Anyone else have this problem?
Intermittently. Sometimes they work perfectly, others not but the lights are recognised in the sim. I press it off and on again and 99.9% of the time it works. Conversly, if you press the button in the sim, the lights on the goflight modules work perfectly.
I've tried changing the settings for the button hold time but it doesn't seem to make a difference. Maybe play around with more settings to see if they help.
Jim
It would require building a brand new program, so effectively starting from scratch - it just wouldn't be commercially viable.
