Developer Support for GIT for X-Plane
I'm currently mapping out all the functions for the MCP Pro for the Rotate MD-80 aircraft. It's actually coming along fairly well.
I spent about 5 hours yesterday and have about 80% full functionality. However I've found some strange inconsistencies. Specifically when it comes to lighting up some of the buttons (I.e. NAV button) it just doesn't behave.
In an effort to do a lot of the mapping I've been doing a side-by-side comparison between the default 737 XML file and the one that I'm editing (through the GIT). I constantly make sure to click "save settings" and export my module-specific XML files in an effort to not lose my work. I've had a good deal of success doing it this way.
The funny thing, there are just times when I'm feeling REALLY confident that I'm using the correct events/variables and not getting the expected results.
Do we have any access to the developer of the GIT? I'd like to share my XML files and get some feedback.
GIT only updates the lights if the data changes, so when you are configuring GIT the value held by GIT needs to change for it to change on the GoFlight hardware. So you can have a situation where the light is on in the Sim but not on in the GoFlight hardware and vice versa. Triggering the light to go and off, thus changing the value will force GIT to synchronise. Its a quirk that only exists while configuring.
If that doesn't help and you are certain of the correct variable, install the DataRef Tool plugin (its freely available) and monitor the variable in that to be absolutely sure it changes and stays changed. If it does, then we clearly have a bug that will need urgent attention.
