Its been 8 months now and i need LUA config For Goflight MCP and EFIS for PMDG 777 and 747
Its been 8 months now and i need LUA config For Goflight MCP and EFIS for PMDG 777 and 747, because i just installed lua config for pmdg 737ngx and it worked can you please provide me.
  • is it normal to have PMDG terms accepted value false even though i accepted "false" on my GoFlight Interface Tool P3Dv4.exe
    GoFlight_PMDG_Interface.Properties.Settings>
    False
    Why do you think you need a Lua script for the MCP and EFIS??!!! The PMDG NGX, 777 and 747 aircraft are automatically configured for both of those devices. You just need to enable them. Please read this beginners guide: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/46-beginners-start-here/151-beginners-guide.html
  • if you had looked at my previous post to support forum i clearly stated that no matter what i do my git does NOT and will NOT recognize pmdg aircraft no matter what i did. i uninstalled and reinstalled git and gf software and it didnt work i uninstalled and reinstalled all pmdg aircraft and it didnt worked i uninstalled an reinstalled p3d and it didnt worked i formatted and reinstalled windows and it DID NOT WORK!!!! for some reason when i open git and pmdg on the log it says that "aircraft loaded: ed martin" its been 8 months now and i cannot use my goflight devices that i paid over 1000$ and i cannot use my git that i paid £29.99 so please help me use my devices. On a forum i saw a lua script for ngx and installed it in fsuipc my devices worked just fine. THATS why i want LUA script gor PMDG777 and 747...... please help me in some way so that i can use my devices it's been 8 months....
  • This makes absolutely no sense. I can only suggest 2 things as GIT has no control over what Simconnect provides:
    1) Uninstall all PMDG aircraft and its very important that no directories remain for PMDG in the flight sim directory - check and delete as necessary. Reinstall and try again.
    2) Wipe your system completely and reinstall
