GF46: Frozen??
Re: Pmdg 737
Recently, I had to wipe files when I upgraded to W10.
Reinstalled current GF Config and GIT.
I set up my 46 with "No Selection" and "Compatible Addon."
The GIT Option page shows Transdcr and 7 other presets.
But when I go to the GF46 tab in GIT to Enable it, the display freezes....flashes dashes...or sometimes just goes dark.
The unit is plugged directly into computer.
Thanks for your help.
Doug
Doug
I've found that as long as it's not on the same powered USB port as the rest of my components it won't freeze.
It could be that despite being plugged directly in to your machine, the PC itself still doesn't provide an appropriate amount of power. I'd recommend attaching a powered USB hub and see how that works. That's what I've had to do since I currently can't run both the 46 and the166 at the same time on one powered USB hub.
There are numerous threads on the forum discussing the many possible solutions to GF46 and GF166 lock ups such as separate hubs, disabling power management for the hubs and GF devices in windows, USB BIOS settings etc. Do a search of the forum and try the things suggested in those discussions.
This is a GoFlight hardware issue, not a GIT issue as I have had the same issues using GoFlight drivers since the year 2008 before I had even written GIT.
The PC has a 600 watt power supply running a GTX 1060 and 970; maybe the two cards are causing fluctuation in voltage to the 46.
Doug
Steev
http://www.devicedriverfinder.com/blog/device-drivers/how-to-disable-power-management-for-usb-root-hubs
Doug
I’ll probably create a regex batch file to quickly update the registry in the future in case Windows decides to revert the selections thru a Windows update.
Doug
