GF46 XML file for Zibo Mod
Does anyone happen to have an XML file for the GF46?
Unfortunately, I do not get this module programmed.
When I go to instructions, nothing works
  • This works for me.
  • You are more than welcome to try this. Default C172 Xplane. Just copy the contents of the Files into the appropriate parts of the XML files. Please Note that it is the Default C172 and NOT the G1000 Variant.
  • It should give you controls On the Panel for Instrument Lighting , Panel Lighting , True Airspeed Indicator (White dial inside the Airspeed indicator), Fuel Quantity Left & right , Outside air temp (at your aircraft) , wind Heading , and wind speed (Both at your aircraft). It also has warning Bells for Low Oil Pressure and Low Fuel Quantity.
