T8 Lights
Hello!
When I select a source for "Light Data" for T8 Switch it seems to be OK, I can choose action and Light Value.
When I save it, restart it, then the Light Data has been disappeared.
Only the action and value saved.
What Do I do wrong???
Krisztian
  • edited November -1
    Hi Kristian,
    Can you tell me what aircraft you are using and what version of GIT you have installed.
    NGX
    I tried 2-0-1131-0, got this:
    22:43:00 SimConnect: Exception Received:  UNRECOGNIZED_ID
    22:43:00 SimConnect: Exception Received:  ERROR
    Then tried your latest BETA, works, but...as I described :)
    Ok, I'll do some testing on the beta release tomorrow with the NGX and T8 to see if there are any bugs.
    Thanks.
    One more found problem:
    With  PMDG IF(Version 1.2.14.0) 166 radio works with standard settings (Com1+Com2).
    With the beta, I got an unhandled-exception:
    {"Requested value 'COM_ACTIVE_FREQUENCY1' was not found."}
    K.
    Just one more info, then I stop flooding :)
    With beta:
    For 46O+R, I set NGX brightness controls, works...
    When I tried to set for an another 46O a DME1/2 (NAV_DME1/2), it does not work... the same the ComboBox does not accept the selected item (after switching option or TAB it contains no element).
    PMDG IF app works correctly.
    I have done a quick test and everything worked OK for me. What actual values are you trying and on what switch? Also list all the goflight hardware you have and how many of each.
    Steve, Thank you for time checking!
    I will make soon a test, with clean installation and settings.
    I will do some screenshot or screencast if needed.
    I have a lot Goflight (166x2, 46x3, P8x2, RP48x1, T8(1-2)x4,
    and assigned a lot of things to them...
