A / P Engage buttons are not kept constant during the flight.
Hi.
I am having problems with the GF-MCP-PRO, specifically with the buttons of the A / P Engage, the 4; sometimes they are activated but they are not kept constant until the flight ends, in some cases they are activated after a while and then deactivated.
Any suggestions what may be causing this problem?
Thank you
Daniel Gamboa
Thank you
Daniel Gamboa
Do the lights match what is visible in the Virtual Cockpit or are they different. If different, what aircraft/flight sim are you using.
The lights are the same, the problem is that the autopilot doesn't engage when I push any of the 4 buttons and when it does doesn't remain staidly.
rgds
Daniel Gamboa
