TQ6 Adv - Reverse Thrust
Hi There,
Thanks for the excellent guides.
I have set up the TQ6 Adv using the guide.
Spoilers, Throttles and Flaps all work fine.
At the end of the guide it says to D/L a file to make the reversers work, but the link appears broke.
Could you please assist me in setting up this last little piece?
Thanks a lot Dave
  • Hi Dave,
    That software is no longer available. It turned into the GoFlight Interface Tool which is now payware. You could also do the buttons via FSUIPC or LINDA.
  • Thanks Steve, I am a registered user of your software.
    If you have a sec could you please advise how to do this in fsuipc?
    Thanks Dave
    Probably need to clarify what I have done. (which I suspect is wrong).
    Your software made the EFIS/MCP & LGT work straight away.
    I assumed you had to use the guide on the site (using FSUIPC) to get the TQ6-Adv working as when it didn't work straight away like the modules did.
    Am I supposed to use your GIT to make the TQ6 work?
    In case you havent guessed, I am not a genius when it comes to software. ;-)
    cheers Dave
  • Ok, if you own GIT, all you need to do is enable the TQ6 in GIT and it will automatically configure the buttons. Obviously GIT needs to be running when you use the TQ6.
    sorry to trouble you.
    I have a strange issue, I have used your GIT to set up my TQ6 - Adv (not FSUIPC as per my first attempt) and when I select the 2nd reverse thrust lever not only does it activate the reverser on the starboard engine it also scrolls the views. ie from virtual cockpit to outside view to wing view etc.
    Can you tell me how to stop this please?
    I am only using the PMDG NGX
    cheers Dave
  • Hi Dave,
    I suspect the TQ6 button has been configured automatically in the flight sim. You will need to unassign the button. It may also be configured in FSUIPC.
