GF-46 for X-Plane
Try as I might, I can't get this module to work. I fully programmed the GF-T8-2 tonight, works like a charm.
Regarding the GF-46, no luck whatsoever. I've followed the instructions in the GIT guide; however, the LED screen on the module is blank. Before trying to assign any functions to it I could press 'Identify' and it would flash D0 and 000000.
I've done the following...
1. On 46R tab, click the first option button, in the clockwise 'Non-pushed' event I selected 'GF45/46_TRANSPONDER_SET'.
2. On 460 tab, click "Enabled", click the first option button, type the Function Name "XPDR".
3. What do I select for the Display Data? And what should the display action/value be set to?
Evidently I'm missing something (since it won't work). Any help would be greatly appreciated.
Also, I should mention that "IDENTIFY" doesn't do anything once I've started setting up selections on the 46 O/R tabs.
Once you have the GF46 stabilised, see if the GF45/46_TRANSPONDER_SET works with a default aircraft and if not give me a shout.
I’ve got the function name displaying and the transponder value displaying. However the events I’ve assigned to the pushed and non-pushed rotaries aren’t working. The bespoke events I’ve created and assigned DO work when I click the “test event” buttons. I’ll attach some screenshots and XML files for my module and bespoke events.
With my current configuration, with my bespoke events assigned to the push in/out of the clockwise and counter-clockwise, the transponder in the simulator updates when I click the "test event" button.
Also, when I change the transponder values in the simulator the display on the GF-46 does change. In other words, clicking the "test event" causes the simulator to work. Also, changing the transponder in the simulator works. It's acting as if changes from the rotaries on the GF-46 doesn't cause the signal to be passed along to the GIT and then forwarded to the simulator. I.e. it's only working in one direction.
When I get home this evening I'll give it another try by clicking the "identify" button. I'll also included some screenshots of my configuration in GIT. Hopefully that'll help.
Regarding USB 1/2/3, my USB hubs are all 3.0. GoFlight's strange insistence on using outdated USB versions makes little sense as they are backwards compatible.
My USB hubs are AK-68ANHUB-B10A (10 port USB 3.0). I had one and ordered a 2nd one yesterday so that I can put the 166's and the 46 on different hubs.
Tried everything I can find on the web - USB hub, USB 1-2-&3, SB pwr management,...etc.
All other GF products worked great with GIT. GF-46 some time worked and some time frozen mid flight, when I'm trying to use it to tune ADF, or some time frozen while changing to view different display. GF-46 would froze even if only program for XPDR.
I'm guessing the communication timing is off, used the GIT delay sliders to max, but still no improvement.
I wonder if GF-46 needed a separate plug-in to manage its connectivity with the Xplane...
Hopefully someone finds a repeatable solution.
When I bought my GoFlight gear in 2008 using GoFlight supplied hubs, I had the MCP PRO locking up, both GF166 units locking up and the GF46 locking up and GIT didn't exist, all GoFlight supplied software and hardware. It drove me mad! In the end, power management, swapping out the hubs and spreading the gear around caused it settle down but it would still lock occasionally and the MCP PRO always locked until the new firmware came out. It took months of fiddling about to get it reasonably stable.
I have heard a lot of people complaining about lack of support at GoFlight. I know when John Krieg was their doing support, my experience of GoFlight support was very good. I haven't used GoFlight support recently so can't comment.
I also hope the company is not going down. With many new competitors entering the market, their lack of responses and activities (at least from my perspective) can drive customers to alternatives.
I have struggled a lot with my panels (GF-45, GF-46, RP-48 and GF-P8) and the most with the 46 and 48. I had it working stable on win7 with XP 11.30. Build a new PC and went to Win10 and the ^%$^& started again. I am using separately powered USB hub.
So after a couple days i got it somehow stable. Couple tips which can be helpfull although i am not sure this solved it. The GF-46 by the way is very sensitive in terms of settings within git.
- If possible use the supplied usb cables instead of other ones. With the 48 and P8 it is not a problem to use other usb cables but the ones with a display it gives sometimes problems.
- Windows 10 power management: disabling the "USB selective suspend". Can’t measure it but i suspect windows to suspend a USB device when it is inactive for a time. So when you are busy with flight planning and don’t use the panels for a moment. Search with google for “How to disable USB selective suspend” in power profiles.
- Increase the timers, especially write and cmd delay to prevend device locks. My work fine on 70 ms.
My2cts
Andre
GIT is seeing the module as it states 1 in the module overview but turning knobs or push button, no reaction is seen in the status overview (green “indicators”)
Anyone a clue? Or share the settings?
Thanks!
Andre
