New GF modules added
I have just added a second EFIS, a GF-46, a GF 168 and a GF-ME8M.
GFconfig does recognize them perfectly, but GIT will not start. I have a red light on the left as shown on the pictures, and the aircraft (PMDG 777) not recognized too. I have tried to change the name off the settings .xml in .off, but no change.
Any solution?
Thank's
Yves
Edit : the log file
  • Not sure what is happening here. Try renaming Documents\Goflight Interface Tool
  • Done. No change. Just no file created in new directory
    I have made further tests : if I disconnect all my new modules, it works. When I add them 1 by 1, it is the MESM which is culpy. All the others work, even together.
    In GF driver it is found, and usable.
    Hope this will let you help me.
    Best regards from Luxembourg
    Yves
  • I will have to check and debug the code at my end before I can come back to you.
  • OK. I'll wait. Please send me a mail.
    Any news 2 weeks later?
    Yves
  • Hi Yves,
    I'm struggling to re-create the issue as my MESM works fine with the 777 and P3D.
    Can you provide the following information:
    - A list of all your Goflight units and how many of each.
    - The version of GIT you are using.
    - The version of P3D you are using.
    - The version of the 777 you are using.
    - Does the MESM work OK with other aircraft or is it with the 777 only?
  • edited February 2019
    I'm using GIT 3,.6.3.1, the latest version of the PMDG 777, P3D V 4.4, and I have connected : 2 EFIS, and 1 of each : MCP PRO, P8, T8, RP48, 46, 466 and the MESM. As I connect the MESM, GIT does not load any more. I'll try with the 737 and tell you more.
    Yves
    Same problem with the 737. Picture joined
    I have installed the new version, after having unistalled the old one and deleted the directories. As soon as I plug the MESM, GIT will not load, and the les stays red. As soon as I disconnect the MESM, no problem.
    Very strange...
    The MESM is perfectly seen in GF driver interface.
    Any Idea???
    Thank's
    Yves
  • I'm still working on it. If I cannot re-create the issue we may have to organise a remote debugging session.
  • OK. I you want, we can eventually make a temviewer connection. I have a licence.
    Send me a PM
  • OK, I think we should so a remote debug session. Let me know when its convenient to do it. No problem with weekends either. Also let me know your time zone.
    You will need to do this on your flight sim PC:
    - Download and install this VPN software (its free for up to 5 computers so don't purchase it): https://www.vpn.net/
    - Sign up for an account in the VPN software. Don't do anything else with it as I will log onto your PC and configure the VPN network.
    - Download and install this for x64: https://visualstudio.microsoft.com/downloads/?q=remote+tools#remote-tools-for-visual-studio-2017
    - Download and install https://www.teamviewer.com so I can access your PC remotely (again its free for personal use)
    - At the time agreed, start up Team Viewer and PM me your Team Viewer ID and password (obviously do not post this on the public forum, PM me!) and we'll see if we can get to the bottom of this.
    Sorry to answer so late, I do'nt go every day on the forum.
    I leave in Luxembourg. I'm one hour earlier then you...
    No need to have a VPN, we can use my teamviewer licence and change the the sense of teamviewer, so you can see my PC.
    I'm free every evening, and some times during day.
    We can exchange teamviewer codes by SMS or what'sapp, I can aloso phone free to UK (as long as you are in UE...)
    Send me a PM.
    Good evening
    Yves
  • We do need the VPN as Visual Studio needs to communicate across it to the Visual Studio tools you will have to install on your PC. So I do need you to do all of those things in the list except for team viewer as you already have it installed.
    One other thing, I will need a local administrator account setup on your PC. Call it Pollypot or something like that and remember the password as I will need to set it in Visual Studio.
    Weekends would be better for me, how about 4pm GMT this Saturday. Just PM me your team viewer ID and password when you are ready on Saturday if OK.
    I think it will be OK after 5PM local time here.
  • I've just tried to connect with your team viewer details you sent, but its not working. Lets reschedule for next Saturday at 4pm GMT. Please make sure you have done everything in the list and also create a local admin account.
    Next saturday it will be difficult for me, it's Easter.
    But we can try tomorrow if you want.
    Just send me a PM, it will be easer because I do not have to connect, or text me.
    Good evening
    Yves
  • How about Friday?
