GIT launch problems
I've tried GIT P3Dv4 64Bit.zip and GIT P3Dv4.zip but neither will successfully prompt me to run the GIT add-on when P3D runs. The help refers to GoFlight Interface Module.dll but I only have GoFlight Interface Module 64.dll. Something is wrong somewhere. A copy of my dll.xml is attached.
Ray (Cheshire, England)
The manual is a little out of date. There is no prompt to run anything in P3D, only for FSX.
Fire up GIT from the shortcut on the desktop and you should be OK.
When I launch P3D and then load a saved PMDG737 scenario GIT tabs become available.
I open the MCPPRO tab and it's disabled. I use the dropdown and select Device 0 and it is then enabled. The MCP shows data and I can change alt, speed, heading etc and see the results on the aircraft. Same for the EFIS.
I save the settings on the Settings tab and exit both GIT and P3D.
When I restart P3D still no add-on prompt and when I start GIT everything is disabled again. Why?
It may look disabled, but it isn't. The device status is only updated when you pick a device from the drop down.
