Issues with MCP-Pro using GIT using FSX-SE with Aerosoft Airbus
Hi team, not sure what I may be doing wrong, but having no luck in getting GIT working with Aerosoft Airbus (using Rob's download), I did have it working once, where only the altitude and heading were adjustable in both directions i.e. from the MCP-Pro and via the mouse on screen. Since then at best I have managed to get the 4 main MCP-pro displays in tune with their on-screen counterparts, but the control is only one-way! Changing their values on screen updates on the MCP-Pro but having no luck in getting any of the MCP-Pro knobs to change the FSX values. All seems to be connected ok (3 green lights etc,) and the MCP Pro works fine in all default FSX-SE aircraft. Any thoughts on why this may be? or what settings I should be using to send info from the MCP-pro into the FSX for the heading?, altitude? vertical speed? etc.
Any assistance, greatly apprecaited.
It could be that the aircraft has been updated and the profile no longer works. I will PM Rob and see if its up to date or not.
Rob has said there have been several updates to the aircraft since he built that config so it probably no longer works. I will remove it from the website.
I hope you can share it with all the users that use this excellent tool, thank you.
I'll wait for the file when it's ready. Thank you again for making our flights happy
Sy
Lindle
