Zibo 738RC1 and GIT 2.0.14.1with Bespoke Events from David Williams
Last days I noticed that there is a difference if I use the "Command A" button in the X-Plane settings and if I press the button at my MCP-Pro CMD A.
If I map "Command A" in X-PLane to a e.g. joystick button and I press this joystick button the knob in the cockpit moves in (like I press it).
If I press the MCP-Pro button, the command works, but the button in the cockpit doesn't move.
Could someone explain why this happens?
Unfortunately my MCP-Pro has a slightly loose connection if I press it. So sometimes I engage and disengage the autopilot. Could this different animation be the reason or is it only my "special" CMD A knob at my MCP-Pro?
Martin
  • Hi Martin,
    I'm running Zibo RC1.8 and GIT 2.0.14.1 and I don't experience the same issue.
  • Hi David,
    if you press the CMD A button at the MCP Pro, does the button in the plane also move in?
    If I press the MCP Pro button the AP is switched on, but the button in the plane doesn't move.
    Sorry that this sounds so crazy, I'll try now with RC1.8 and report back.
    At the beginning of your work for the Zibo B738 I had to copy a command.txt and DREF.txt to the route folder of the Zibo. Now this isn't necessary now?
    Martin
  • edited March 2019
    Hi David,
    checked and back again. If I set the CMD A button to my Saitek Throttle button it is the same command (laminar/B738/autopilot/cmd_a_press)
    If I press this button at my Saitek Throttle the CMD A knob in the plane move in and out. I attached a short video of this.
    But if I use the same command with the MCP Pro, the AP CMD A is set to on or off, but this animation of the button isn't there.
    As long as the AP works it is ok, but I'm only interested in
  • Martin,
    I went back and ran some tests. I may have jumped the gun with my original comment as none of the buttons animate in XP.
    Not a big issue as long as the functionality of the button works.
    Steve, Is this something that you can have a look at some stage. The command A button is assigned the laminar/B738/autopilot/cmd_a_press command.
    Thanks.
  • Hi David,
    I'm not sure what is going on there, but I will take a look.
  • In easy words, if I use the same command in X-Plane the CMD A button in the plane moves in and out. The same command with GIT the button don't move (but the setting is ok). Not really a big problem, but interesting what is causing this.
    Best wishes,
    Martin
