Wrong algorithm for aircraft name detection in GoFlight Interface Tool
Hello!
I have most 3rd party planes installed in separate folders, so i have in fsx.cfg such lines:
SimObjectPaths.6=SimObjects\AirplanesAdd
SimObjectPaths.7=SimObjects\AirplanesTraf
when i load a plane, that is in this folders, GoFlight Interface Tool determine aircraft name as 'FSX'
i was trying to figure out what is going on and moved files from SimObjects\AirplanesAdd to SimObjects\Airplanes\Add and changed fsx.cfg to
SimObjectPaths.6=SimObjects\Airplanes\Add
and after that Interface Tool detected name as 'Add'
I think wrong algorithm was used, you should get last directory component of aircraft path but not first after SimObjects\Airplanes.
Thanks for the feedback, I'll look at the code and find out what is triggering the regex match to fail.
Thanks so much.
Alex
