Using GIT and T8 switch to connect GRD PWR via CDU
Given the problem there is with the GRD PWR LED not functioning correctly on the 737 I've decided to adopt a different approach.
The SDK includes the relevant commands for each section of the CDU and via GIT and FSUIPC.INI I've successfully programmed the CDU button presses to enable GRD PWR instead of having to navigate via the mouse. Those commands are via a T8 switch.
What I can't work out is whether I can assign a command to the Light command so it's either on or off according to whether that option is selected in the CDU. This is what I have but the LED is always on. Can you help please?
Ray (Cheshire, England)
I have just had a look in the SDK and nothing is available.
You could fake it, by creating a bespoke event for turning it on and another for turning it off and in there set a Bespoke Variable to either 0 or 1 and then assign that Bespoke Variable to the LED.
E.g. Using "Bespoke Var 0", On would be:
Send EVT_CDU_L_MENU
Set Bespoke Var 0 1
and Off would be
Send EVT_CDU_L_MENU
Set Bespoke Var 0 0
I shall try that tomorrow. Thanks very much.
Control ID="1" EVENTType="NGXEvent" EVENT="EVT_CDU_L_MENU" ACTIONType="EventCmd" ACTION="CUSTOM" LIGHTType="Var" LIGHT="Bespoke Var 0" LIGHTACTIONType="LightCmd" LIGHTACTION="ON" LIGHTVALUEType="Float" LIGHTVALUE="1" ACTION_OFFType="EventCmd" ACTION_OFF="CUSTOM" /
I've removed the leading and trailing < > as the code wasn't showing in my post.
Send EVT_CDU_L_MENU
Switch Bespoke Var 0
Case 0:
Set Bespoke Var 0 1
Case 1:
Set Bespoke Var 0 0
EndSwitch
Then assign this bespoke event to your ON event on the switch.
Detective is disabled with the PMDG737 loaded.
sendevt("EVT_CDU_L_MENU", MOUSE_LEFTSINGLE) if (getbvar("Bespoke Var 0") == 0) then setbvar("Bespoke Var 0", 1) else setbvar("Bespoke Var 0", 0) endAssign the Lua code as you would a normal event, Look for LUA_ followed by the script name you entered.
Having done all that I've hit a problem. The switch I want to assign to that LUA script currently holds all the commands used by FSUIPC to navigate to the CDU and select keys to turn GRD PWR on and off. If I replace those with the call to the LUA program then GRD PWR won't work.
I suppose the solution is to embed those commands into the LUA program. I'm pasting them (bit cheeky!) in case you can embed them.
70=P109,1,C70183,536870912 -{Custom control: <70183>}-
71=P109,1,C70176,536870912 -{Custom control: <70176>}-
72=P109,1,C70168,536870912 -{Custom control: <70168>}-
74=P109,1,C70167,536870912 -{Custom control: <70167>}-
75=P109,1,C70168,536870912 -{Custom control: <70168>}-
76=P109,1,C70169,536870912 -{Custom control: <70169>}-
77=P109,1,C70171,536870912 -{Custom control: <70171>}-
78=P109,1,C70171,536870912 -{Custom control: <70171>}-
79=U109,1,C70183,536870912 -{Custom control: <70183>}-
80=U109,1,C70176,536870912 -{Custom control: <70176>}-
81=U109,1,C70168,536870912 -{Custom control: <70168>}-
82=U109,1,C70167,536870912 -{Custom control: <70167>}-
83=U109,1,C70168,536870912 -{Custom control: <70168>}-
84=U109,1,C70169,536870912 -{Custom control: <70169>}-
85=U109,1,C70166,536870912 -{Custom control: <70166>}-
86=U109,1,C70171,536870912 -{Custom control: <70171>}-
87=U109,1,C70171,536870912 -{Custom control: <70171>}-
P represents a switch on; U represents a switch off. 109 is the button ID as shown in FSUIPC. You will know the rest probably.
Sorry to ask basic questions.
if (getbvar("Bespoke Var 0") == 0) then setbvar("Bespoke Var 0", 1) else setbvar("Bespoke Var 0", 0) endYou can assign this to the switch and assign you key commands in FSUIPC to the same switch.Best wishes
Its not going to be possible in GIT until the completely rewritten version is released at the end of the year'ish
You might be able to do it in FSUIPC using Lua and Pete's GoFlight Lua commands.
The problem seems to be that you need a light which does not exist in cockpit - the EP IN USE LT, which is located at EP Connection panel. In my understanding the logic behind this LT is as follows:
EP LT ON CASE: if ON GND and EXT PWR LT ON and EXT PWR SW ON
EP LT OFF CASE: ifnot EP LT ON CASE or EP LT ON CASE and then AT LEAST ONE APU GEN SW ON or EP LT ON CASE and then BOTH ENG RUN WITH GCB ON
EP and APU providing elec power whichever was switched at last but not in parallel, ENG overrides EP (if in use)
Maybe you can program a logic depending upon switch settings and light ON/OFF variables.
Best regards
But thanks for your interest.
Best regards
