Setting GF SECM Strobes to Zibo 737
Hello,
I need help. I want to use the selector "Strobe" of my SECM to switch the Strobes of the Zibo 737 from Steady directly to Strobe & Steady. As my selector only have on and off, I must jump over the off position. No I found out that I can use Input action repeat and this works. Is this a problem or will this repeat endlessly in one or the other direction?
Martin
Martin
Is there an easy and quick example to create a bespoke event for a simple switch?
At the moment I feel really stupid. Sorry.
I've learned slowly and the next questions popping up. I managed to create a bespoke event for my FF A320 for example. With set+ and value 1.0 I can move the switch up and set- and value 1.0 the switch down. But what can I do, if this switch have 3 positions. How can I move it up or down with one command.
Martin
Thinking about you could send the Commands that you previously used twice in the bespoke events instead.
You may need a Sleep task in-between the 2 Set- and Set+ tasks to allow time for the dataref to be updated.
Martin
back to the Zibo 737. I was able to create bespoke events for all, for me relevant, switches. Only with the strobes I've problems.
I added 2 screenshots. There are 6 commands, which change if I set the strobes from STEADY position over OFF position to STEADY & STROBE position.
Now I want to put a command to the Strobe switch of the SECM which moves from STEADY position directly to STROBE & STEADY position. If I use the standard command laminar/B738/toggle_switch/position_light_pos and make a bespoke event with set 1 and -1, this doesn't work.
Martin
sim/lights/strobe_lights_on
sim/lights/strobe_lights_off
I'm using the Aircraft config from David Williams for MCP-Pro and EFIS. This could not be an issue?
I found out, if I use laminar/b738/toggle_switch/position_light_up and down the switch in the cockpit work, but only one step up and down. Down position is STEADY, middle position OFF and up possition STROBE & STEADY. And I want to got directly up from down to full up position.
Could use input action REPEAT, but this would be not good?
Martin
Send laminar/b738/toggle_switch/position_light_up
Sleep(50)
Many thanks, Steve!
Best wishes,
Martin
