AUTOPILOT_MACH_HOLD_VAR issue
Hello!
I tryed to make 'C/O' button on GF MCPpro work with default FSX Autopilot as expected.
bespoke event for it:
<Task ID="2" Type="SetInc" Var="Bespoke Var 0" Data="1" />
<Task ID="3" Type="If" Var="Bespoke Var 0" Operator="GREATER_THAN" Value="1" />
<Task ID="4" Type="Set" Var="Bespoke Var 0" Data="0" />
<Task ID="6" Type="If" Var="Bespoke Var 10" Operator="EQUALS" Value="1" />
<Task ID="10" Type="Goto" LabelID="7" />
<Task ID="12" Type="SetEquiv" Var="Bespoke Var 10" Data="AUTOPILOT_AIRSPEED_HOLD_VAR" />
<Task ID="14" Type="Goto" LabelID="8" />
<Task ID="7" Type="Label" Name="a" />
<Task ID="16" Type="SetEquiv" Var="Bespoke Var 10" Data="AUTOPILOT_MACH_HOLD_VAR" />
<Task ID="8" Type="Label" Name="b" />
Display source for IAS/MACH display setted to "Bespoke Var 10"
There are two issues found:
1) AUTOPILOT_MACH_HOLD_VAR is always truncated, I tryed use it as source for display also, display shows 0.00 while mach number less than '1' and 1.00 when greater
2) I hadn't find a way to set display format from bespoke event, so it seems impossible to have for example '266' for IAS and '0.55' for mach without every time correcting field format settings by hand. And absolutely impossible to have '0.551' for mach.
Is any solution of second issue possible?
It will happen automatically when I fix the data type bug.
