DECISION_HEIGHT_INC and DECISION_HEIGHT_DEC not binds on controls correctly
Hi, Steve!
Another one bug report from me.
When i try bind  DECISION_HEIGHT_INC and DECISION_HEIGHT_DEC events to DHMDA knob of GF-EFIS, it doesn't work, and Detective dont't show event send,
when i move send of events to bespoke event it works fine, and Detective  shows events.
with best regards
Alex
  • edited November -1
    Hi Alex,
    I just assigned them fine. Saved the settings, restarted the interface and then re-selected the rotary DHMDA (important to do that otherwise it may look like its not assigned).
    Hi, Steve!
    I haven't understand what do you mean, this is part of my current config:
    <Cluster ID="1" Controls="2">
    <Control ID="0" EVENTType="SimEvent" EVENT="DECISION_HEIGHT_INC" EVENT_OFFType="SimEvent" EVENT_OFF="DECISION_HEIGHT_DEC" />
    <Control ID="1" EVENTType="SimEvent" EVENT="KOHLSMAN_INC" EVENT_OFFType="SimEvent" EVENT_OFF="KOHLSMAN_DEC" />
    </Cluster>
    KOHLSMAN_INC / KOHLSMAN_DEC works absolutely fine, DECISION_HEIGHT_INC/DECISION_HEIGHT_DEC doesn't work
    with best regards
    Alex
    Hi Alex,
    It could be the aircraft you are using does not respond to those events. Check in Detective by using the controls in the Virtual Cockpit and see what events get sent. Also make sure you add the event action "Rotate".
    Hi Steve!
    Trouble exists for any default aircraft, and for non-default that I've test
    It works fine for all those aircrafts if i send the same events from bespoke event
    with best regards
    Alex
    Hi Alex,
    Found the bug. The simconnect event names were wrong. They have been changed to:
    DECREASE_DECISION_HEIGHT
    INCREASE_DECISION_HEIGHT
    Expect a new version over the weekend.
    Hi, Steve!
    I'm glad to hear that bug is located, I will check a new version.
    with best regards
    Alex
