Export/Import renamed bespoke vars
Hello, Steve!
I tryed to export one plane configuration for import it to configuration for another plane, and there was some renamed bespoke vars,  configuration doesn't imports correctly, program shows errors and deletes all tasks with renamed vars.
I renamed variables back to 'Bespoke Var nn' , exported config and now it imports without errors.
Please fix it someway.
with best regards
Alex
  • edited November -1
    Hi Alex,
    That isn't supported at the moment. You can manually do it by copying the section in BespokeVariables.xml of the exported plane and recreating it for the plane you are importing.
    Hi, Steve!
    Seems renaming of bespoke vars is unuseful now, better just don't use it yet.
    with best regards
    Alex
    They are fine so long as you don't export to share with others.
