MCPPro button behavior with Zibo's B738-800 (MCP PRO, EFIS, GF166, LGTII) by David Williams
I've been using the GIT config from David Williams's Zibo B738 mod. I have to hold the MCPPro buttons before they activate. For example, I need to press the HDG button for at least one second before it actual is reflected in the MCP and Mode Annunciator. I can press it and it will momentarily show "HDG" but if I release it, then it clears. You have to hold it for at least a second perhaps more. Is there any change that can be made to the config program to decrease the time you need to hold a button before it actually takes affect in the simulator?
