PMDG/TQ6 Advanced
I have installed the latest builds of the GF software and the PMDG interface software. I have to enable the Device 0 and 737 Throttles each time the pmdg software loads. I also receive the message "reg AppPath entry not found..PMDG options file cannot be updated..." I have neither fsx nor Prepar3D checked in the settings (I have tried all combinations--same results). I would appreciate any assistance--Thanks,
Robert
Steve--The NGX--
Robert
OK. It looks like the registry entries for FSX are missing. Flight1 have a registry repair tool here:
http://www.flight1.com/view.asp?page=library
Can you check this file exists <your drive>:\Program Files (x86)\Lockheed Martin\Prepar3D v2\PMDG\PMDG 737 NGX\737NGX_Options.ini and if it does, post the contents on here.
The registry entries for Prepar3D are missing which means Prepar3d didn't install properly or the registry has been corrupted. You should be able to turn off the two tick boxes in settings, then quit GIT and reload it. The error message should stop showing up.
As regards your settings, go into the FAQ off the Support pull down menu on the website and use it to locate your settings file. Zip it up and attach it to this discussion for me to look at.
