MD82 Yellow Simconnect
On my PMDG aircraft I get all green lights. When I load the MD83 I get a yellow simconnect and the import button is greyed out. Any ideas?
11:15:36 GoFlight Connection Starting.....
11:15:36 SimConnect Connection Starting.....
11:15:36 SimConnect Message Processing Started
11:15:36 GoFlight Connection Started
11:15:36 SimConnect Connection Started
11:15:36 Aircraft Connection Starting.....
11:15:36 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
11:15:36 SimConnect: Event Received: SIM, 1
11:15:36 SimConnect: Event Received: PAUSE, 0
11:15:39 WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
11:15:39 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
11:15:41 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
11:15:41 Aircraft Connection Started
11:15:41 Simconnect Version: 4.0.0.0
11:15:41 Aircraft FullName: MaddogX
11:15:41 Synchronising Switches & Selectors .....
11:15:41 LvarNamesUpdated!
11:15:41 Creating Bespoke Vars
11:15:41 Bespoke Vars Created
11:15:41 Importing Bespoke Variables
11:15:41 Bespoke Vars Assigned, Importing Bespoke Events
11:15:41 Bespoke Events Temp Imported
11:15:41 Bespoke Events Imported
11:15:41 Loading Aircraft Settings
11:15:42 GetXMLConfigData
11:15:42 GotXMLConfigData
11:15:42 Loading Power
11:15:42 Loading MCPPRO
11:15:42 Loading EFIS
11:15:42 Loading P8
11:15:42 Loading T8
11:15:42 Loading RP48
11:15:42 Loading MESM
11:15:42 Loading WP6
11:15:42 Loading LGT
11:15:42 Loading LGT II
11:15:42 Loading GF46
11:15:42 Loading GF45
11:15:42 Loading TQ6
11:15:42 Loading DIO
11:15:42 Loading GF166
11:15:42 Loading SECM
11:15:42 Loading Joysticks
11:15:42 Clearing Displays
11:15:42 Reset Data
11:15:42 Aircraft Settings Loaded
11:15:42 Calling Aircraft Changed
11:15:42 Aircraft Changed
11:15:42 LvarNamesUpdated!
11:15:42 Creating Bespoke Vars
11:15:42 Bespoke Vars Created
11:15:42 Importing Bespoke Variables
11:15:42 Bespoke Vars Assigned, Importing Bespoke Events
11:15:42 Bespoke Events Temp Imported
11:15:42 Bespoke Events Imported
11:15:42 Loading Aircraft Settings
11:15:42 Loading P8
11:15:42 Loading T8
11:15:42 Reset Data
11:15:44 Synchronising Switches & Selectors Complete
