Import .zip CTD?
Trying to import a .zip config file and after point to it and click ok both GIT and Gflight crash. Did any else get it imported?
  • What aircraft is it?
  • Sorry, Fly The Maddog.
  • You need to do a manual install as per your previous thread. It looks the file has something wrong with it.
  • I saw that post, are there instructions on how to manually load? I tried doing what was posted but it failed as well.
  • Those instructions in the thread should work. It may be you need to clean up first. With the aircraft VC showing, go into Detective and delete all the bespoke events (big red X), then clear the configs for the devices you attempted to load. Then try again.
