I built a test environment running Windows 10, FSX and GIT using the French language and GIT worked OK, so I no longer think its an issue with language.
I'm suspecting something wrong with the GoFlight drivers. Can you remove all your GoFlight equipment from your PC and try running GIT and let me know what happens. If it works OK, add one piece of GoFlight equipment at a time to isolate what piece of hardware if causing the problem.
I'm just back from a long travel and i have re-install GF 2.28 and the new GIT 3.6.3.1 and now it work then i have plug GF LGTII,MCPPRO and GF EFIS : everything work perfect .
When i plug GF-MESM the problem come back and it lock everything
On my side i have check when i open GIT first with GF LGTII,EFIS and MCPPRO it's ok and after i plug MESM,GIT work normally but MESM don't work
I come back to see if you solve the problem to use MESM because i try again and he don't work??
Andre
I try renaming GoFlight Interface Tool,nothing appear on my screenn,then i plug only the MESM and i start GIT,everything in red light and GIT completely lock,i have to resart my computer then i have tested this way
1-start GIT look like ok and then i plug MESM and it work perfect
2-re start GIT with LGTII,MCPPRO and EFIS and everything look like ok again and then i plug MESM now everything work perfect
3-Last test,i re-start GIT with all components plug including MESM and again everything lock,really strange
Andre
- MCPPRO
- EFIS
- LGTII
- MESM
Andre
No news after my last message regarding my MESM
Andre
I have an MCPPro, GF-RP48, 3 x GF-T8-2, GF-MESM, 2 x GF-166, GF-46.
Everything works well when I do not connect the MESM. As soon as I connect it, everything freezes.
I look forward to seeing if you have found this weekend the reason for this problem.
Good day and best regards.
Laurent
Andre
Like before, everything works well when I do not connect the MESM
If i connect MESM,everything freeze and it's finish ,we have to restart
Andre
No more news for the MESM because many friend in our team are waiting to buy the system and they don't want to be in front of the same problem?
Andre
I have been working with another customer with the same problem to arrange a remote debug session as I cannot re-create the problem, but he has let me down. If you are willing to do a remote debug session which may take up to 2 hours of your time, then please do the following:
You will need to do this on your flight sim PC:
- Download and install this VPN software (its free for up to 5 computers so don't purchase it): https://www.vpn.net/
- Sign up for an account in the VPN software. Don't do anything else with it as I will log onto your PC and configure the VPN network.
- Download and install this for x64: https://visualstudio.microsoft.com/downloads/?q=remote+tools#remote-tools-for-visual-studio-2017
- Download and install https://www.teamviewer.com so I can access your PC remotely (again its free for personal use)
- At the time agreed, start up Team Viewer and PM me your Team Viewer ID and password (obviously do not post this on the public forum, PM me!) and we'll see if we can get to the bottom of this.
Let me know when its convenient to do it. I would prefer late afternoon GMT, say 4ish. No problem with weekends either.
Already i have
- Hamachi is installed and have an account
- Teamviewer also is working
- just i finish to download visual studio
wich way is the best for you to pass my Id and password?
Everything is ok just i go out again tomorow for some few days.
I contact you on the way back
Andre
Je viens d'installer la dernière version 2.0.15.2 et je n'arrive toujours pas à faire que le MESM soit actif.
Toujours le même problème, sans MESM tout fonctionne à merveille, avec tout se fige.
Juste une autre question:
Peut-on faire qu'au lancement de GIT, les modules connectés soit actifs par défaut car, à chaque fois je dois activer tous mes modules ?
Merci pour votre aide et bonne journée.
lolopilote
Cela fait plus de 6 mois que ça dure et toujours pas d'issue pour le MESM,je pense que lorsque l'on vend un logiciel ou un materiel,on s'assure qu'il fonctionne avant de faire la transaction ce qui n'est pas le cas.
Ou en est tu car j'ai été pas mal absent?
Andre
There is no fix, because no one has arranged followed through on a remote debug session. I cannot fix what I cannot re-create. If you want a resolution, lets agree a remote debug session so I can see what is going on.
When i come back i agree to organize a debug session on my computer to fix this situation,i can do nothing before
Best regards
Andre
Could you purpose a date to organize a debug session on my computer to fix this situation
Best regards
Andre
It will have to be next week, if that's OK.
Ok for next week but could you give me an zdvise the day before on my mail box : andreeymard@orange.fr
Thank you
Andre
