MCP Pro using GFIT works with FSX Default aircraft but Fails with all PMDG
I desperatly Need Help Please:
MCP Pro works fine with Fsx Default Aircraft but I only get Dashes when running any of the PMDG Aircraft.
I have installed and reinstalled GF Config and GIT in (X86) directory as well as in their own separate directories (DID NOT WORK)
Installed and Reinstalled all of the PMDG Aircraft (DID NOT WORK)
Reset the PC and re installed Windows 10 to no effect.
Current Installations:
Flight Simulator X is in C:\Fsx
GOFLIGHT Config and GFIT is installed in C:`Program Files\ (X86) Directory
GF Config = Version 2.2
GFIT Config= Version 3.6.5.1
Uninstalled all PMDG Aircraft
PMDG 737NGX
PMDG 777 200 LR/F
PMDG 777 300 ER
PMDG 747-400 QES II
PMDG 747-8 QES II
Reinstalled only PMDG 737NGX to test if Goflight Works. It Does Not
Have Checked the Options.ini Data Broadcast is set to 1
Net framework is updated v3.5 and 4.8 for windows 10
Dll.xml Points to the right Path
GoFlight Interface Module
False
C:\Program Files (x86)\GoFlight\GoFlight Interface Module 32.dll
GF Config is set to Compatible Add-on and is directed to C:`Fsx
GFIT Recognises the loading of the Pmdg Aircraft and the Log shows everything connected and working ok.
I really don’t know what else to try. If the GFIT recognised the default aircraft it should somehow also recognise the PMDG aircraft.
PLEASE HELP.
PMDG 737NGX
PMDG 777 200 LR/F
PMDG 777 300 ER
PMDG 747-400 QES II
PMDG 747-8 QES II
False
PLEASE HELP.
PMDG 737NGX
PMDG 777 200 LR/F
PMDG 777 300 ER
PMDG 747-400 QES II
PMDG 747-8 QES II
Checked the operation Centre...The Version is 1.20.8885 and it states it is up to date
Thank you
I am SO SO Grateful. I have been trying for a week deleting and installing everything.
THANK YOU THANK YOU
Wondering if I can use an older version of GIT as it worked fine on my old Win8 pc
I cannot think of anything that would make the aircraft behave like that.
Thank you so much. You have been most helpful.
