GoFlight Interface tool freezes upon start (was working before)
I'm using the GoFlight Interface tool succesfull for some time. But suddenly it freezes upon start-up for no reason (or maybe not obvious to me). I have not made any changes to my system (Windows 10, P3Dv4, GF-config tool, etc.), at least not that I'm aware of. Tried to start the software with P3Dv4 and PMDG B737 since than for several times, but result remains the same.
The GoFlight modules which I have not programmed through GIT continue to work w/o any problem.
I'm using GoFlight Config v 2.2, GIT v 3.6.5.3.
What did I try until now?
- Checked if the Internet security suite (ESET) has any influence. But even when deactivating the firewall and virus protection, the GIT still freezes.
- I re-installed GIT
- Went to C:\Users\your username\AppData\Local\Pollypot_Software and delete everything in that folder and then try starting GIT again. GIT still freezes.
- Reset my PC to a previous backup, in which GIT was still working, but GIT still freezes.
I cannot retrieve a LOG-file from within GIT, as it freezes and doesn't allow me to enter GIT. I can close it only though Task-Manager.
How can I approach the problem? Any idea what could be the route cause?
Looking forward to any idea / hint what to do.
Detlef
  • You may be using older Goflight drivers. Make sure you are using the latest.
  • I was already checking, in fact I assume that I'm using the latest GoFlight driver which is 2.28 but I cannot check since GoFlight Homepage not reachable. GIT driver is 3.6.5. And as I mentioned before,it was working perfect for a few months. W/o any obvious reason from one day to another it didn't work anymore.
    Today I de-installed GoFlight and GIT completely and after restart installed it again. But without success, GIT continues to freeze upon start-up.
    What could be the next step to check? Maybe a Windows 10 update has an influence?
    Thanks for your ongoing support.
    Detlef
    2.28 is the correct version. I would rename Documents\GoFlight Interface Tool so GIT starts without any config data and see if that works. If not unplug all your GoFlight gear and plug in one item at a time and start GIT. Rinse and repeat until GIT locks up again.
  • I am experiencing the same symptom. Did not experience this issue before on P3D v4.3 and earlier version of GIT. This seems to have come about after upgrading to P3Dv4.5HF1 and upgrading GIT version to latest 64bit version. I'm using v2.28 GoFlight drivers for MCPPro and EFIS. I'm running Windows 10.
    Most of the time it works, but about 1 out of 5 times, GIT will hang.
    I start GIT before P3D and it will ALWAYS start, displays green lights for GoFlight and I can interact with the UI, no problem. After starting P3D, everything is still fine, green lights for GoFlight and SimConnect.
    When I select the PMDG 737 aircraft in P3D or load a situation for the PMDG 737 this is when, on 1 out of 5 occasions, GIT will hang displaying the same as the Op's screenshot. I have to terminate the process in windows taskmanager. Unplugging the GoFlight hardware and restarting GIT will result in another hang as soon as the PMDG 737 is selected in P3D, so rebooting is the only option to rectify.
    Hope you can help. Please let me know if i can provide any further information.
    Darren
  • Hi Darren,
    Can you try the 32bit version of GIT for P3Dv4 and see if the issue remains.
  • sure, will do Steve, I'll report back
    I tested with 32bit version and the same issue exists.
    Darren
  • Hello Steve and Darren,
    for me it worked out to rename Documents\GoFlight Interface Tool. GIT created a new directory and it works just fine now. I only had to programm again a few buttons and that was it.
    Thanks for the support. Without the hint I would never have solved it.
    Detlef
  • Thanks Detlef - I will try this. Did you experience the same as me i.e GIT starts ok but hangs when PMDG aircraft loaded?
  • Yes, GIT was freezing only when starting the PMDG B737NGX. With a standard airplane GIT worked without freeze.
    But now GIT is working again fine also with PMDG.
  • great, thanks
  • Hello I have the same issue, so what file do I have to rename ?
  • If it is freezing and NOT showing an error message, then iff you have a backup of Documents\Goflight Interface Tool, restore from that backup. If not rename Documents\GoFlight Interface Tool to start with a clean config.
  • Ok I’ll check it out thanks
  • I need to try this as I’m having the same problem. I don’t understand how and what you are renaming. Thanks.
  • Hello Gerry,
    I'm having several GoFlight modules in use, also more than one of most types (i.e. 3x P8, 2x T8, etc.).
    GIT always freezes, if the GF modules are changeing the USB #. i.e. one P8 has been programmed as device #0. With the next PC-start, suddenly this particular P8-module becomes #1 and another P8 module becomes #0. In that case GIT freezes. It is recomended to delete the old GIT-directory under 'Documents', GIT will create a new 'empty' folder and you have to re-program the GF-modules.
    As it may happen that with the next PC-start the GF-modules will be configured again with the 'old' setup, I don't delete the 'old' GIF-directory but only rename it (i.e. GoFlightInterfacetool_old). Than GIT will also create a new directory and I have to re-start programming my modules.
    If I face the same problem again and the order of the GF-modules changes back again to the previous order, I don't have to re-programm again but only re-activate the previous directory to the original name and it will work again. At the same time I re-name the 'not working' directory. That way I can switch between the 2 setups w/o needing to re-programm the GIT again and again whenever my PC changes the # of the GF-modules.
    I hope I was able to explain in an understanable way.
    Detlef
  • Thanks Detlef. I got it. Much appreciate your help. I have another guestion if you don’t mind. Using a GoFlight T8 module for example how can I have a switch programmed to have two functions. For example flipping the switch up have it turn on something flipping it down turn off. Trying to be clear a single switch has the function to turn on and turn off. Hope I’m making sence.
    Thanks again for getting back to me.
    Gerry
    Gerry
    If its for a PMDG aircraft, you can't as only one Event can be set (The new version of GIT being developed will allow this though). For other aircraft select OFF in the combo box next to the Event and choose the Event you want to use when the switch is in the Off position.
  • Much thanks. I should have added that this is for an iFly 737. I’ll give it a try.
    Gerry
