It looks like your settings file has got corrupt. Please rename Documents\GoFlight Interface Tool to something else so GIT starts clean.
PS: If that works, you will need to restore the files from a backup. There is an automatic backup in Documents\GoFlight Interface Tool\Backup which may or may not be corrupt. If using these files remember to rename them from .bak to .xml
But I deleted the program completely and installed it again
But the same problem
And you delete the files in this path
Reinstall the program again
