  • edited July 2019
    It looks like your settings file has got corrupt. Please rename Documents\GoFlight Interface Tool to something else so GIT starts clean.
    PS: If that works, you will need to restore the files from a backup. There is an automatic backup in Documents\GoFlight Interface Tool\Backup which may or may not be corrupt. If using these files remember to rename them from .bak to .xml
  • edited July 2019
    Thanks for your kind reply
    But I deleted the program completely and installed it again
    But the same problem
    And you delete the files in this path
  • edited July 2019
    I don't know what you mean, but you do need to rename that directory as it never gets deleted by an uninstall.
  • Manually delete it
    Reinstall the program again
  • Are you deleting Documents\Goflight Interface Tool and not Program Files (x86)\GoFlight Inteface Tool?
  • edited July 2019
    OK, go into C:\Users\Your UserName Here\AppData\Local\PollyPot_Software and delete all directories in there.
  • thankssssssssssssssssssssssssss :)
