Can not get my MCPPRO to work
I have had the MCPPRO for a number of years and have never had any real problems with it however i now have a big problem, i can not get it to work. I have downloaded the latest interface tool P3D 64 BIT and when i fire it up everything is greyed out and i can not move or close the interface tool, i have to shut it down via the task manager. I have lines across all of the the dials on the actual hardware and am now getting pretty frustrated as i do not know what else to do, any help woul;d be appreciated
Once you have tested both versions and neither work test if GIT is working with default aircraft with the MCP PRO? Test by loading up the Beech Baron 58 and clicking the Default FS button on the MCP PRO tab and then ENABLE it for the aircraft. It should come to life. To make sure its GIT doing it and not the GoFlight drivers, right click on the blue and black aircraft icon on the notification area of the Windows Taskbar and choose quit. GIT should be the only thing driving the MCP PRO now. If that works OK, then I can only suggest a reinstall of the PMDG aircraft or you find out what changed on your system that broke it and roll the changes back. I really need the log - its there to help me diagnose problems. Can you copy and paste it into a file and attach to this thread for me to look at tomorrow. If you quit GIT before attempting to use it with a PMDG aircraft, the log won't be that long.
09:52:48 SimConnect Message Processing Started
09:52:48 GoFlight Connection Started
09:52:48 SimConnect Connection Started
09:52:48 Aircraft Connection Starting.....
09:52:48 Prepar3D v2 ini file not found
09:52:48 Prepar3D v3 ini file not found
09:52:48 PMDG SDK option is OK in Prepar3D v4
09:52:48 SimConnect: Event Received: Aircraft Type Changed
09:52:48 SimConnect: Event Received: SIM, 1
09:52:48 SimConnect: Event Received: PAUSE, 0
09:52:48 GoFlight Connection Starting.....
09:52:48 SimConnect Message Processing Finished
09:52:48 SimConnect Connection Starting.....
09:52:49 Creating Bespoke Vars
09:52:49 Importing Bespoke Variables
09:52:49 Bespoke Vars Assigned, Importing Bespoke Events
09:52:49 Bespoke Events Temp Imported
09:52:49 Bespoke Events Imported
09:52:50 SimConnect Message Processing Started
09:52:50 GoFlight Connection Started
09:52:50 SimConnect Connection Started
09:52:50 Aircraft Connection Starting.....
09:52:50 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
09:52:50 SimConnect: Event Received: SIM, 1
09:52:50 SimConnect: Event Received: PAUSE, 0
09:53:22 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
09:53:22 Aircraft Connection Started
09:53:22 Simconnect Version: 3.4.0.0
09:53:22 Aircraft FullName: PMDG 777-200LR
09:53:22 Synchronising Switches & Selectors .....
09:53:25 Synchronising Switches & Selectors Complete
