Xplane 11 zibo mcppro
Does anyone know if that should be considered normal ? Zibo and goflight mcp. Check the screen and the actual mcp.
Im using pollypot soft. As is. With one of the setup for zibo that is available for download.
    No not normal at all. I have had the 1 knot difference but I just tried to reproduce it and everything worked perfectly. When it happens to me again, I'll take a bit more notice and try and track it down. In terms of all the lights, it's definitely not normal. I do have some issues when changing modes. The previous mode light stays illuminated as well as the new modes light.
    The V/S window should be blank when zeros.
    I've attached a latest copy of the profile that I have. Remove your old one and import the new and see how you go.
  • thanks david! i'll try it !
  • edited October 2019
    Hello Everybody
    Since the version of Zibo 3.36 and 3.37. There are some buttons of the MCP Pro hardware that do not sync with the panel of the aircraft.
    you press VOR LOC or APP or VNAV, LANAV ... etc and they do not light up on the plane. but it's random
    the opposite works very well
    Do you notice the same problems ?
    GoFlightInterfaceTool_SetupX-Plane_2_0_15_2 -w10 - XP11.36
    edit i dont see : i loadt latest copy of the profile and i try with him
  • I had the exact same issue as you, lights and displays out of sync and frequent crashes of the MCP Pro hardware too. I changed the following things and have been trouble free ever since on both short and long flights...
    1. On the MCP-Pro tab in GIT, change Write delay to 20ms (this syncs the lights and displays perfectly for me. Anything higher doesn't sync properly) and change Cmd delay to 100 (anything lower causes hardware lockups for me).
    2. In detective, I increased all the Sleep values by a factor of 4 under each bespoke command in David's code. The initial "Start" bespoke variable, I think, was causing my crashes and I now have that set to 480ms. I've quadroupled all the other sleep values (except IAS up and down) to play on the safe side and haven't noticed any bad side effects.
    Like I say, trouble free ever since and I haven't had the IAS mismatch of 1 kt since. I know everyone's hardware/setup is different, but hopefully it'll work for you too.
    Russ
    hello Russ,
    modification 1 ok
    modification 2 nok
    I have not managed to know what to change in detective as you a photo ?
    except that now GIT is buged what is so the initial values ​​of Write delay and of that I I give them
    thanks
  • Hope this helps
  • I should add that you have to have X-Plane running to get into Detective. When you make these changes in Detective, with X-Plane still running, you should ALT-TAB into GIT and close it down, Then unplug and replug the MCP Pro back in. Go to Device Manager and check MCP Pro is ok (i.e. no there is no "!" showing) and then restart GIT. Then ALT-TAB back into X-Plane and hopefully it'll work okay. Next time you start GIT and then X-Plane you won't have to do any of this again. Hope that makes sense!
  • i'll try too tonight when im back home!
  • Hello Russ,
    yes the picture and your details will help me but I'm afraid to make mistakes while it works not too bad it should not be worse.
    I would also like the guys from Pollypot to give their opinion on these problems
    thanks a lot
    Roland
  • How can I set the light value of the leds higher, because the leds are far way to difuse for me .
