Sudden issues with he interface tool
HI. I have been using the Goflight mcp for a few yeas with no issues. overnight it seems to have stopped working.
The Go flight config starts all ok and all the indicator lights light up so it is recognized, when I start the GIT only the "simconnect /FSX" goes green the other two indicators remain red and the GIT program seems to lock. I cannot get into settings or the log. Any ideas?
    Make sure you have the lastest GoFlight drivers. Try renaming Documents\GoFlight Interface Tool so GIT starts clean with no config in case your settings file is corrupt.
  • Thanks, did that, it stop the program freezing. All the green markers are now green but its not going anything with the MCP to copy part of the log which looks like it has a couple of errors. Text file attached.imageimage
  • Those errors won't impact the NGX. Have you enabled the MCP in GIT, because its disabled by default.
  • Yes I had that issue the first time i used the program and remembered to do that.. I have now reset the pc and am reloading from scratch. Which version should I use there now seeps to be a few. windows 10 P3D v4, im guessing its the 64bit version?
  • If you are running P3Dv4 then yes.
