GIT and Engravity CDU PMDG won't run together
I used GIT and the Engravity CDU PMDG for quite some time on FSX with the PMDG 737; they worked perfectly. I recently upgraded my PC, installed P3Dv4.5 on W10. Subsequently I installed the P3D PMDG and both Pollypot products (new downloads). Separately they work fine again, but...
When I first start GIT (with the PMDG 737 running), GIT works fine, but after starting the Engravity CDU PMDG it doesn't give me 'three green'; only the left most 'flashlight' turns green, the middle and right most remain red, and the Engravity CDU remains blank.
If on the other hand I first start the Engravity CDU PMDG it works fine ('three green', I can use the CDU), but after starting GIT I get several message boxes with lots of errors; the main error seems to be 'The process cannot access the file 'C:\Users\Bert\AppData\Local\Temp\SyGdktWDSxJu9wbLtOksza==£LockheedMartin.Prepar3D.Simconnect.dll' because it is being used by another process' I assume the "another process" is the Engravity CDU PMDG, but they worked fine under FSX.
Do you know what the problem is; or even better :-) how to solve it?
Thanks in advance, I'm looking forward to hearing from you.
Kind regards,
Bert Hilberink
