Brightness not working on RP-48
Setting brightness within GIT for my new RP-48 is not working. Several levels of brightness doesn’t work.
I can confirm that the new RP48's do not support brightness changes. It doesn't work with GoFlights own drivers either.
Another question.
Can i run GIT in a windows 7 virtual machine so that all modules keep working. I think it is possible but i think that GIT is connecting via 127.0.0.1 because i see pipe connect failed...
Attached a picture what i want to achieve.
Thanks!
In this case GIT is running in the VM and the plugin in the host (win10). So i want that GIT is communicating from the VM to the plugin. (Redirecting local loopback address is not possible of course) Is the LUA config file located in the GIT installation directory?
Thanks again
