Registration Failed! -202 Exceeded Install Cou
Good evening,
I've seen other people with this issue that's been fixed with a reset of the install count, so could I get that please?
Adrian
  • Hi Adrian,
    I cannot find your order from the email address you have used in the forum so it must be different. Can you PM me your details so I can reset your install count.
  • Hallo,
    I have the same problem. After installing GIT on new Hardware no registration was possible. Could you please reset my Account too
    Best regards
    Mike
  • Hi Mike,
    Your install count is fine. Make sure you have the latest version of GIT as it fixes a registration problem.
    Thanks for your help. Indead i installed an old version. After taken the actual version all works very fine without any problems.
    Best regards
    Mike
